Question about LG 22" FLATRON LCD Monitor
I have a LG monitor, run windows xp - I got it to fill the screen but the right half of screen is clear and bright the other darker, it's like there is a line down the middle as if you were editing a photograph, say, enhance and it splits the pic showing you the betterment on one half of the picture. How do I fix this. I want it to look all clear like the one side. PS this does not effect clearity of printed words or picture.
  • LG Master
  • 2,517 Answers
Its is the problem of your monitor display. please contact service center ASAP.
Posted on Jan 30, 2010
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Hi there, We have a LG Flatron W2253TQ monitor and the display is half normal, half very bright. There's a perfect line down the middle - the left half displays normal colours while the right half...
It could be some sort of "Demo" mode on the display, try going into the menu of the display and looking for settings relating to Flatron F-Engine, it has a demo mode that could be the problem. That is the most likely cause since its exactly half the screen.
May 17, 2011 | LG W2253TQ-PF Monitor
I have an lg monitor flatron w2453v, right now it works great but the screen is split, what i mean is half of it is good the other side is a hint darker, how do i fix this?
Hi, Usually what it means when a screen is darker on one side than the other is that the " backlight " has becom weak. You can try turning the overall " Brightness " down and this may lessen the problem a little. In my opinion that's what should be causing the problem. Good luck, I hope this helps, Prodzilla.
Apr 11, 2011 | LG Computers & Internet
On my monitor W1941S half of area (left side) changed all colours to darker then right side (which is o.k.), What is the problem? Thank you.
Press f-Engine button (it is on the right side of MENU button), select your desired setting, if it doesn't help, select the "X" (none) mode - the half dark screen will reset to full screen OK mode.
Jan 08, 2011 | LG W1941S-PF Monitor
I'm tring to restore original settings on my LG monitor and keep getting "osd lock" message. Half my monitor is very bright, the other half it 10-15 shades darker.
I held the "Menu" button down for 15 sec. and it unlocked. Then used the Auto Set feature. It didn't work immediately on the two-towned
screen, but corrected itself within 1/2 hr.
Thank you.
Feb 08, 2010 | LG 22" FLATRON LCD Monitor
Upper half of the monitor is darker
I would try an auto-adjust first see if that helps any, also you could try it on another PC to make sure its not your video card on your PC. Another option is to reset the screen to its factory defaults see if that does anything.
Sep 30, 2009 | Samsung SyncMaster 932B LCD Monitor
LG Flatron w1952TQ screen half darker on right side
Try clicking the auto adjust button on the screen. If this doesn't work it may be in demo mode, so click the fENGINEbutton on the monitor and make sure it is selected on the normal setting.
Aug 04, 2009 | LG Flatron L1919S LCD Monitor
HALF SCREEN IS LIGHTER THAN OTHER HALF
Press the 'Engine' button that there is on the screen and select 'Normal'
May 26, 2009 | LG Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Brightness
most monitors get darker with age -- for a while you can counter this by turning up the Brightness and Contrast controls, but this only gives you a little extra time (and probably speeds up the decay process anyway).
Sep 16, 2008 | LG Studioworks 563N 15" CRT Monitor
LG 22" FLATRON LCD Monitor Logo
558 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
