Question about GE JVM1650 1000 Watts Microwave Oven
My ge jvm1650 starts to work for a couple of seconds then display goes to wanting me to reset the clock & date. When I do this it will start then go back to the same (reset the clock & date).
  • GE Master
  • 9,047 Answers
This is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in the GE bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 and posted by William E. Miller prototech@usa.net (permission granted)
(I the poster am the copyright holder on this and hereby grant permission to this site keep this on its site)
(PLEASE do not be fooled into thinking that the procedure outlined at this link is a "fix". It should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.)
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a Ziploc bag and insert a flat piece of aluminum foil into the Ziploc and close it.
Then (with the power off) tape it over the circuit board as best you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 31, 2010
2 Suggested Answers
SOURCE: my ge jvm1650 starts to work for a couple of
replaced the unit.
Posted on Jan 25, 2010
Microwave resets after start
See this FixYa solution. even if your model number is different.
May 23, 2010 | GE JVM1650 1000 Watts Microwave Oven
Model JVM1650WH02 will shut off about 2 seconds or less into cook time. everything else works such as light and clock and sometimes the wave will cook.
magnetron is leaking internally, do not use until magnetron is replaced. the mag creates interference with the control board and resets it
Feb 05, 2010 | GE JVM1650 1000 Watts Microwave Oven
Microwave not working
Sadly, we hear of this over and over.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit.
They may send you a replacement magnetron. GE Customer Service is here.
Nov 25, 2008 | Microwave Ovens
SET CLOCK. TRY TO USE. IT SHUTS OFF AFTER A FEW SECONDS.
I found an envelope with troubleshooting info inside the microwave on the left side behind the front vent. A troubleshooting flowchart was included which indicates that this problem is caused by the high voltage capacitor. I got mine out pretty easy and ordered one from appliancepartspros.com for $55 (which includes expedited shipping. I hope this info helps.
Sep 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
The microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Oct 03, 2007 | GE JVM1650 1000 Watts Microwave Oven
Shuts off, must reset clock
Sounds like you could have a fauly control circuit. Something like when you press the pad the processor does not interpret the information correctly and resets itself. Or the power going to this circuit is being interupted. It is VERY dangerous to work inside of a microwave. So you could get an estimate from a repair shop. But those control boards are expensive. Do not attempt to repair this yourself. For your own safety.
Aug 06, 2006 | Frigidaire PLMV168 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
341 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
