Question about Code-Alarm Code Alarm Transponder
HOW DO I DISARM A FORD TRANSIT ALARM TO PREVENT BATTERY DISCHARGING WHEN NOT USED EVERY DAY
  • 344 Answers
I don't show this car as having an alarm, but if your battery is discharging everyday without driving it there is a problem somewhere else, tis is not normal and should still be under warranty
Posted on Feb 14, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
06 Ford Escape Hybrid. I didn't drive it and the battery died. Alarm settings are messed up need to reset to factory settings. Help!
I am not real familiar with Hybrids. In general, to go to a default setting you would disconnect the regular battery for at least 10 seconds and the systems should reboot. It does not cost to try this.
Jul 20, 2017 | 2006 Ford Escape
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
Battery discharging on transit van when not being used
Have the battery checked as they fall over, a cell at a time, anywhere from 2 - 5yrs. Yrs could be shot.
Jul 25, 2012 | Ford Transit Cars & Trucks
The alarm system has activated and we cannot disarm the system via the Remote Key Fob or by key at the doors or hatchback. Tried disconnecting battery same problem. When the doors open the system...
Hi Edward:
In dashboard, your THEFT warning light is blinking? If the answer is yes, your antotheft system is activated and will need restart and resynchonized. This occurs when battery is disconneting or other un-authorized key is used.
Vehicles equipped with Vehicle Theft Security System (VTSS) are protected from vehicle theft andunauthorized entry. VTSS system monitors vehicle doors, hood, liftgate and ignition. If an attempt is made toenter or operate vehicle without proper disarming of system, vehicle horn will sound, headlights, taillights andparking lights will flash, and engine will be prevented from running.
VTSS system arms when ignition is off, vehicle is exited, door is locked using power door locks and door isclosed. Alternatively a remote keyless entry transmitter can be used to arm system. A security light on panelwill flash for 15 seconds to indicate system is arming. At the end of 15 seconds, if no door, hood or tailgate isopened, system is armed.
If alarm is triggered, horn will sound for 3 minutes, and lights will flash for an additional 15 minutes. If hornsounds 3 times when either front door is unlocked, vehicle has been tampered with (tamper alert). If doors arelocked manually or with key, system will not arm (manual override). If an unauthorized entry does occur, VTSSsystem signals Powertrain Control Module (PCM) to prevent vehicle from being driven. PCM reduces injectorpulse width to zero, causing a start and stall condition.
System can be disarmed with the keyless entry transmitter, or by using key to enter vehicle. In both instances, if alarm was activated, vehicle alarm will be terminated. If battery is disconnected and reconnected, alarm will beactivated and it will be necessary to disarm system as indicated.
Please, send us some email account to send you this procedure in PDF format file.
Feb 08, 2012 | 1996 Jeep Grand Cherokee
When i try to start me 2008 sonata the alarm goes off and the engine will not turn over. what can i do?
Your Sonata is equipped with a "Keyless Entry & Burglar Alarm" system. When the Burglar Alarm is activated, it KILLS the starting system through the used of a relay called the "Burglar Alarm Relay". This mode prevents engine starting with the key.
Solution #1
Disarm the system with the Keyless Remote (key fob) If you don't have this remote (or its battery is dead) replace the battery & try disarming again.
Solution #2
Enter the vehicle & insert the key in the ignition and turn the ignition switch to 'RUN'. Wait 3 to 5 minutes until the alarm stops. You should then be able to start the engine.
Have a qualified/certified Hyundai Service Technician properly diagnose this issue.
Sep 07, 2011 | Hyundai Motor 2004 Sonata
How do i disarm my ford transit alarm because sometimes when i open it then start it up the alarm goes off?
Look in your fuses under the hood and under the dashboard. Hope this helps?!
Please rate and comment - Thank You
Sep 23, 2010 | Ford Econoline Cargo Cars & Trucks
Remote won't disarm alarm. and alarm has kill switch to the engine.
hi you may want to check on the remote battery, so you can disarm your alarm, it happens when your remote battery needs a replacement, have a nice day
Feb 12, 2010 | Car Audio & Video
Ford factory alarm arm output and disarm output
I don't show this truck as having a factory alarm, is there maybe an aftermarket alarm in it
Dec 28, 2009 | Code-Alarm Code Alarm Transponder
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
Code-Alarm Code Alarm  Transponder Logo
1,062 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
