Screen not lighting can here windows opening and am told to remove memory on back and reinstall where is this located
  • 526 Answers
You need to be a little more specific.
1. are you using a notebook or a desktop?
2. do you see anything on the screen?
if your using a notebook and you see no display,
then it means your inverter is most likely bad, and the lcd screen will need to be replaced.
if its a monitor connected to your desktop, i would check the cables and also the contrast and brightness buttons on the screen. if that still does not work, most likely, you have a bad monitor.
thanks adi
Posted on Jan 30, 2010
Compaq Presario CQ56-115DX bluescreen
wwats happening is you may have 1 of your simm memory chips that are bad theres a small cover on back of laptop that is about 3.5 x 3.5 inches square take off that plate and youll see 2 memory simms take out 1 and reboot if problem persist try removing other and putting first one back then reboot if problem persist put simm back in again then reload windows using your disk and reinstall windows that will fix this issue your having your lcd sounds like its fine though
Feb 27, 2013 | Compaq Presario CQ56-115DX Laptop
2001 dodge durango /tail light troubleshooting
Open the rear door, locate the two screws next to the tail light. They will be philips head. Take them out, pop off tail light, unhook light harness. Reinstall is opposite of removal.
Sep 01, 2012 | 2001 Dodge Durango
My dell optiplex gx620 does not start and it shows no. 3 and 4 lights illuminated on its front . what could be the problem.?
One of your memory chips is bad.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Diagnostic Lights caution.gif CAUTION: Before you begin any of the procedures in this section, follow the safety instructions located in the Product Information Guide. To help you troubleshoot a problem, your computer has four lights labeled "1," "2," "3," and "4"on the front or back panel. The lights can be off or green. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. When the computer starts normally, the patterns or codes on the lights change as the boot process completes. If the POST portion of system boot completes successfully, all four lights display solid green. If the computer malfunctions during the POST process, the pattern displayed on the LEDs may help identify where in the process the computer halted.
note.gif NOTE: The orientation of the diagnostic lights may vary depending on the system type. The diagnostic lights can appear either vertical or horizontal.
Light Pattern
Problem Description
Suggested Resolution
The computer is in a normal "off" condition, or a possible pre-BIOS failure has occurred.
The diagnostic lights are not lit after the computer successfully boots to the operating system.
Plug the computer into a working electrical outlet and press the power button.
A possible BIOS failure has occurred; the computer is in the recovery mode.
Run the BIOS Recovery utility, wait for recovery completion, and then restart the computer.
A possible processor failure has occurred.
Reinstall the processor and restart the computer.
Memory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer. (see "Memory" for instructions on how to remove and install memory modules.)
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, contact Dell.
A possible graphics card failure has occurred.
  • If the computer has a graphics card, remove the card, reinstall it, and then restart the computer.
  • If the problem still exists, install a graphics card that you know works and restart the computer.
  • If the problem persists or the computer has integrated graphics, contact Dell.
A possible floppy or hard drive failure has occurred.
Reseat all power and data cables and restart the computer.
A possible USB failure has occurred.
Reinstall all USB devices, check cable connections, and then restart the computer.
No memory modules are detected.
Memory modules are detected, but a memory configuration or compatibility error exists.
An other failure has occurred.
This pattern also displays during System Setup and may not indicate a problem.
  • Ensure that the cables are properly connected to the system board from the hard drive, CD drive, and DVD drive.
  • Check the computer message that appears on your monitor screen.
After POST is complete, all four diagnostic lights turn green briefly before turning off to indicate normal operating condition.
None.
Jun 06, 2012 | Dell OptiPlex GX620 PC Desktop
When i turn on my laptop it just shows the compaq logo and stops. The desktop dose not appears.
Here are two options:
1. Boot pressing F12 and choose to boot to last good configurations.
2. Remove the Battery, pressing power button holding it for 1 minute and connect back with battery and power adapter.
Jul 06, 2011 | Compaq Presario CQ60-220US PC Laptop
How to transfer pictures from computer to camera memory card?
Below is how to transfer your photos incomputer to a memory stick in Windows XP operating system 1. Insert the memory stick into a compatiblememory stick reader. Plug the memory stick reader, with the memory stickinserted into it, into the computer's USB port. 2. After a moment, a screen thatsays "Removable Disk" will pop up and prompt you to take an action.Click on "Open folder to view files using Windows Explorer." Thiswill open the folders on the memory stick. Select and open the folder whereyour photos are stored. 3. With the memory stick folderand the photo folder open simultaneously, use the mouse to click-and-drag thephotos to the memory stick folder. 4. Close all folders and removethe memory stick reader from the USB port. 5. To ensure that your photos havebeen transferred, plug the memory stick back into the USB port. When the"Removable Disk" screen pops up, select "Open folder to viewfiles using Windows Explorer." Once you see the photos on the memory stickfolder, you can close the folder and remove the memory stick reader from theUSB port.
Jan 08, 2011 | Fuji FinePix J10 Digital Camera
My web cam is not detected
You may need to perform a clean install of the Logitech camera software if it didn't install properly or a another program in memory is conflicting with it. Removing the camera software and reinstalling it using a clean boot procedure may resolve the symptoms you are experiencing.
The following instructions will walk you through this process:
Remove the Logitech camera software.
  1. Unplug the camera from the computer. Later you will be prompted by the software to plug in the camera; do so at that time only.
  2. Open the Windows Control Panel.
  3. Open the Add / Remove Programs window.
  4. Locate the listing for the Logitech camera software and remove it. When prompted to remove the camera drivers files, click Yes.
Prepare the system for installation of the Logitech camera software.
    1. Go to the Logitech Downloads Page and select your product to download the correct version of the Logitech camera software.
    2. Please see here for the clean boot procedures.
    3. Doubleclick the icon for the Logitech camera software download file.
    4. Follow the on-screen prompts to complete the installation.
  1. Return Windows to its normal state.
    1. Use the instructions located here to enter MS Configuration window.
    2. Place checkmarks in the items that you previously removed them from.
    3. Click OK and allow the computer to reboot.
    4. Test the Logitech camera software to ensure your original issue has been resolved.
    Please ensure that you are using QuickCam 11.8 if you have Windows Vista or Windows XP
Dec 20, 2010 | Logitech QuickCam Express Web Camera
I turn on my Acer Aspire 3050 and get a power light but, nothing on the monitor. I have tried taking off the battery and unplugging the power source, holding down the power key for 20 seconds. When I try...
If you do have the devices displayed on screen when you start it ..before getting to windows screen ..and this blank screen only gets after ..It may be a windows error ...and reinstalling it or running the recovery partition will fix this ..It may be related with the updates for video card ..made auto ..and installed a wrong driver or setting ..(unsupported ) ..If this is the case try to turn it off by unplugging ..and will give you the boot mode screen ..where you should load safe mode..If you manage to load it in safe mode just reinstall the video driver for it and it may work ..
Another case it may be a damaged display screen or damaged wiring or the inverter for it ..(in this case you should check and see what s wrong and change the inverter if it is the case..Basically you will have just shadows on screen and miss the back light )..
anyway ..try to see if it starts to bios at least ..and if it does..it is just a corrupted windows and need to be reinstalled from scratch and will work ..
If it does not load windows either bios settings ..but still opens and looks blank ..(this I assume it does not mean it do not open ..but opens and shows an empty screen ) You may see the cause for not loading BIOS ...the cmos may be damaged or the battery for it empty ..and you will need to reinstall Bios ..
Usually if it is a damaged video card will not open at all and make some beeps noises ..so this may be excluded..So ..it is either the operating system ..or the wrong driver for video ..(and wrong ..unsupported setting ..and in this case will even load windows but you can not see it pass the windows logo ..and you should hear the log in ..
Or it may be something wrong with the ram memory and in this case is explainable if it does not load bios settings ..To see about this..just open the back lid for ram memory ..and remove them ..and place them back one by one ..and try to boot up each time ..If it shows devices and loads at least bios ..with one ..it means it works ..check them all and eliminate the faulty ones..Try several times to press them in the slot ..cause sometimes just do not make a good contact and nothing wrong with the modules physically .
Oct 06, 2010 | Acer Aspire 3050-1733 Notebook
''error loading operating system'' on Nec Versa laptop.
First if you haven't already unplug the power and take out the battery for a minute or so. Then reinstall the battery and connect power. Then try and start in Safe Mode, To do this start consistently pressing and releasing the F8 key while pc is powering on, continue until screen should display a similar screen as when turning on normally. From there ( hopefully it has started up ) you should be able to go to START MENU> click/open Control Panel> click/open ADD OR REMOVE PROGRAMS and start removing any programs, if not all, that look like they are using a lot of memory. Doing the SYSTEM RECOVERY is going to uninstall EVERYTHING and reinstall it anyway. Also remember you can only have one security program running other wise they will conflict with each other and cause numerous problems.
Clear temporary files and browsing history. Open IE, even if you don't ever use it, open TOOLS> open INTERNET OPTIONS> In the BROWSING HISTORY section click DELETE > Then click DELETE ALL
One other thing you may want to do is START MENU> RIght click MY COMPUTER> click PROPERTIES> click ADVANCED> click SETTINGS in the PERFORMANCE box and select 'LET WINDOWS CHOOSE WHAT'S BEST FOR MY COMPUTER'
Hope this helps.
Nov 18, 2008 | Computers & Internet
I could not access BIOS or anything else on my computer.
Starting the PC without memory will result in a ?beep code? error, which is the beeping you are hearing. Replacing the memory should make the beeping go away. As far as accessing your BIOS if you PC won?t display anything they accessing your system BIOS won?t accomplish anything. -When you start your PC with the memory installed do you see anything displayed on the screen? -Was the PC operating correctly before your reinstall? -Why did you void the CMOS? -Why did you remove the PC memory?
Jul 23, 2007 | FIC P4M-915PD1 Motherboard
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
