Question about Lowrance Lcx 112c 10.4" Screen Color Gps And 200 Khz Sonar System
Will Airmar TM258 transducer work with the Lowrance LCX 112C
3 Suggested Answers
  • 157 Answers
SOURCE: Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
Posted on Oct 19, 2008
SOURCE: Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Posted on May 12, 2009
How much torque on the transducer mounting bolt?
I install these and other Lowrance systems.
For me there is no specific amount of tourque, it's primarily your best judgment.
You want the bolt tight enough so that the transducer doesn't pivot while on plane but if it were to collide with something it would pivot up out of the way.
May 22, 2015 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
My depth finder keeps loseing the bottom and just flickers the last reading
Hi, if this happens when stationery check the angle of the transducer, if it only happens when moving check the height of the transducer also. Regards Phil
Jul 02, 2012 | Lowrance Lcx 38c Hd Fish Finder Gps (200...
Transducer loses bottom at any type of speed greater than trolling. Worked fine last year with all the same setttings. All I can think of is , maybe the battery is low. The boat just came out of storage...
Check the transducer for any damage on the front part. Also make sure there isn't any damage on the bottom of the boat that is causing air bubbles to cross the face of the transducer. If it works at slow speeds there is definitely something causing air bubbles.
May 08, 2010 | Lowrance Lcx 27c 7" Gps Fish Finder Combo...
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
Lowrance 112c gps shuts off when cranking main engine?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
May 08, 2009 | Lowrance Lcx 112c 10.4" Gps Fish Finder...
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
LCX-25C seems to be cycling on & off when in the sonar mode.
Did you ever get your problem fixed, I having the same issues.
Ken
Apr 17, 2009 | Lowrance LCX-25c GPS Receiver
Oct 07, 2008 | Boating
Lowrance LCX-16ci - screen's gone out
I have a working unit with a bad antenna. Interested?
Davidwcantrell@comcast.net
Apr 09, 2008 | Lowrance GPS
Lowrance Lcx 112c 10.4" Screen Color Gps And 200 Khz Sonar System Logo
151 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
