Question about Motorola Mobility RAZR V3c Cellular Phone
Razr v3 can not remove a torx screw tight top slightly stripped
    Brigadier General:
  • 7,752 Answers
You need to take the phone and have it fix
Posted on Jun 29, 2008
How do i remove front panel on meile washing machine w404 plus to rnew door seal
Hi, It would appear that there is alot of miss leading information written here.
Anyway here goes:
Firstly isolate power, It will be easier to view internal workings if the top panel is removed first (remove the cover clips on the side of the top panel to gain access to retaining torx screws) then slide panel backwards to then lift off.
Next..There is a torx fixing screw just just behind the suds draw which needs removing, remove suds drawer completely (press release mechanism) undo screw and keep safe.
The next job is slightly more tricky, pull of control knob carefully, you will then need to remove the facia panel to access the screws behind (facia panel with machine washing details) for this you'll need to use 2 x small stiff pointed implements a couple of stiff sharp pointed kitchen knives will do.
Now this is the tricky bit, locate the points of the knives on the very top edge of the facia panel, gently and firmly push the panel downwards being very careful that you don't slip as you may damage the panel or cut yourself. The panel will slightly move down as it rests on 2 x wire spring clips, your need to prise the panel towards you as you depress this will then allow the facia panel to be removed. Be careful not to loose the spring clips taking note of there position.
Now that bits out of the way the rest is plain sailing.
Remove the 2 x torx screws behind the facia panel located at each end undo and keep safe, carefully remove this electronic panel it will not completely drop out due to the wire connections that's not a problem as you don't need to remove it completely you just need to access a further 2 x torx screws behind this by moving it to either side carefully.
Once you've removed the plastic housing torx screws you can prise out the plastic surround housing casing carefully.
You will now see 2 x torx screws sitting on top of the main front panel these will need removing with the right hand one being a little awkward to access due to the plastic housing dangling in the way.
Next open the front chrome loading door (use the pull cord located behind the filter access door) remove the 2 x torx screws which hold the door locking mechanism (don't worry the mechanism won't fall down behind the front panel when the screws are removed) keep safe.
Next is to remove the lower kick strip at the bottom if the front panel to access fixings screws. You'll need to gently but firmly tug the plastic panel towards you gripping at each end. Once removed undo the 2 x torx screws on the very outer edge the others will not need to be removed.
Lastly going back to the door opening to remove the bolt underneath the rubber seal using a 10mm spanner undo remove and keep safe. Care at this point will be needed as the front panel will only be held on by the door opening grey rubber seal.
obviously if you wish to remove the rubber seal this will then totally disengage the front panel from the machine.
refitting is the reversal of dismantling.
i hope this helps others as I had nothing to work to as there was no information on the net of youtube.
if I've missed any parts out appologies as I'm doing this from memory.
Oct 20, 2014 | Miele W404 Washer
How to set tps on a 2001 gsxr 1
Step 1: Remove front seat
Step 2: Locate Dealer Mode connector, it resides just behind the battery, it is a white connector with a rubber cover on it, it has 5 or 6 wires going into it.
Step 3: Put bike in dealer mode, take a paper clip or a wire with two stripped ends and connect the two pins
To ensure the bike is in dealer mode, look at the gauges and the temperature should be replaced with "C00" and a little "-" next to the code, the "-" is what you will be observing while adjusting the throttle position sensor. There are three positions of the "-" (top, middle, bottom)
Step 4: Remove the right side fairing
Step 5: Locate the tamper proof torx screw
it's behind the cable bundle you see running along the top of the triangular hole in the frame
You can get the torx head screwdrivers needed for this screw at any auto parts store, just ask them where to find the tamper proof torx screwdrivers. I couldn't find my torx head driver, so I'm unsure of the proper size needed.
Step 6: VERY Slightly loosen the torx screw (the black plastic piece behind the torx screw is your TPS)
Step 7: Reach into the frame and grip the TPS and begin observing the "-" on the gauges. Adjust until the "-" JUST hits the top position. Find the point that it juggles back and forth between middle and top then move it up just far enough that it doesn't juggle anymore. VERY carefully tighten the screw, if you're not careful the TPS will move while you're tightening the screw.
Step 8: Remove paperclip or wire from dealer mode switch, and replace the rubber cap
Step 9: Re-assemble bike and ENJOY
Feb 23, 2013 | 2001 Suzuki GSX-R 1000
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Camera
try master resetting the phone.
Or reflash the firmware on the phone.
Jun 23, 2008 | Motorola Mobility RAZR V3
Can't find sim card for removal
the sim card is not under the battery, as in you take it out and see it, the sim is downwards from the battery.
Jun 22, 2008 | Motorola Mobility RAZR V3
Cleaning flex cable on Razr
The FLEX cable doesn't ever need to be cleaned. If your screen became blank it's probably because (among other things) the flex cable IS broken, not dirty.
May 05, 2008 | Motorola Mobility RAZR V3
Tighten T6 2 screws? With what and huh? I'm a dumb girl... clarify
You remove the battery cover. At the bottom end of the battery area there are 2 screws. Remove the battery and slacken them slightly and then retighten gently. You need a Torx size 6 driver and a set can be purchased at the likes of Maplins for a few pounds. As for cables you will need to remove back completly to check them.
Mar 31, 2008 | Motorola Mobility RAZR V3
Key Pad
Tiger, u gotta take ur phone apart, Using a torx screw driver (about 10 dollars at radio shack or walmart) and on the display side, remove the 4 screws with the torx screw driver, using some type of blade take apart the display, remove the connector with a knife or something really thin, and with some kinda brush (a tooth brush will work) brush the two sides of the connector since i m sure u ll see alot of moist in the same connector, and put it back together and that should fix ur problem.
Feb 07, 2008 | Motorola Mobility RAZR V3
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Motorola Razr: small mount of water contact.
Yes, once the dot turns red it will not go back to white. you can disassemble your self, but be careful. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
Nov 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
