Question about Sram Force Double Tap Shift/Brake Levers
I have just installed my first set of SRAM shifters (2010 Force). The back (right) one did fine; however, the front one (left) shifts fine from the small chainring to the large, but going back down it is stubborn and makes a CLACK sound - not smooth at all. I assumed it was my ignorance, so I took it to my local bike shop and asked them to connect it to the front derailleur. It came back doing the same thing. Is this a common malady? Sure seems like a shifter defect. Can you help? THX, Mike
  • stmick Jan 31, 2010
    My problem is not how to wire-up a front derailleur. That was done and it works. The problem is the CLACKING sound in the shifter and the stubborness of it shifting from the large ring to the small ring.
  • 74 Answers
Before you install the cable shift it in the position of small ring ,then insert the cable pull it and tight the screw in the front deraileur(left lever)to it same to the right
Posted on Jan 31, 2010
The front derailer on my sram red compact just wont change quick!
Which brand of shifters are you using? A SRAM derailleur won't work with Shimano shifters and vice-versa.
So - first; if you are using SRAM shifters with the Red derailleur - then changing to Shimano will not solve your issue but only make it worse.
If however you have Shimano shifters - then this is a good solution.
The Red derailleur should not shift that poorly with SRAM shifters. It is not the best - but it's not bad. If I had the bike in a repair stand I would be looking carefully at the following after affirming that the shifting system was indeed all SRAM:
  • Derailleur cage height relative to the large chanring - should be a maximum of 2 mm
  • Derailleur cage should be aligned as close to parallel to the rings as possible
  • Derailleur upper and lower limit screws should be adjusted within spec and in order to allow the derailleur to travel the correct amount for ideal shifting
  • Derailleur cable tension should be correct.
Hope this helps... Let me know if you need more.
Oct 28, 2012 | Sram Red
To whom this may concern; I've riden many many many miles on my road bike with the SRAM Force break leaver with integrated double/tap shifting. Recently however it was having trouble with keeping the...
I'd revisit the adjustments first before spending that kind of money. It sounds like cables have stretched and simply need to be readjusted, which may be normal.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Ask yourself this... Why would the left shifter have anything to do with this and how do you know you'd get an 'improved' set on a new purchase?
Maybe look on eBay periodically for a deal or a stray right shifter.
Aren't boutique parts fun?
Jun 27, 2011 | Sram Force Double Tap
I have a Campy 10 Speed Shifter, running with SRAM S60 wheels, it causes some problems when upshifting
If you are running a SRAM or Shimano Cassette, then the spacing will be ever so slightly off. If you want to have precise clean shifting then you need to either replace the cassette body with a Campy one and replace the cassette with campy or get a 10-speed conversion cassette such as those from American Classic. Campy spacing on a shimano/ Sram spline.
The wheels in and of themselves should not make any difference.
Another trick for perfect shifting, make sure that your rear derailleur and shifter match - Campy to campy, Sram to Sram as examples.
Jan 02, 2011 | Cycling
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
The scale (from 1 to 9)does not move. it stays on 9 and does not move, but it shift very well
The Scale, known as the gear indicator, has no bearing on the function of the shifting. It is a simple device that connects to the derailleur cable and moves with the cable back and forth as you shift. if it is stuck, then it is broken. As long as the indicator does not affect the shifting then it is probably not worth the replacement procedure, which is repalce the shifter assembly.
If you take the bike into your local bike shop, they can process a warranty for you. SRAM is very good about warranty, and if this part is less than 2 years old you have a very good chance at it being a waranty issue. SRAM however does require you to go through a shop to warranty a product.
Dec 07, 2010 | Sram X7 Trigger Shifters Mountain Bike...
Installed new front sram x9 trigger shifter & its overshifting
You might have to consider changing your bottom bracket for one with a longer shaft. Examine your chain line and do some research here:http://www.parktool.com/ and also here:http://sheldonbrown.com/gearing/index.html
Oct 15, 2009 | Cycling
Sram Force Double Tap Shift/Brake Levers Logo
259 people viewed this question
Top Sram Cycling Experts
hgpilot
John Egan
John Egan
Mike
Are you a Sram Cycling Expert? Answer questions, earn points and help others
