Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
Where do I find a replacement cooling fan for a lincoln 225 stick welder?
    Problem Solver:
  • 6 Answers
I took my old one to Grainger and they ordered a new one that is 230V. Total cost of motor and fan $27.00
Posted on May 04, 2010
  • happydonald1 Aug 16, 2011
    Do you know exactly what part # you ordered. I called grainger and they said it was an oem product. They didn't carry it. I have a lincoln 225-s model arc welder. Don
My AC 225-S welder is missing the wiring diagram. The cooling fan wires are pulled apart. Need to know if the fan is 110 or 220 and where to put the wires back. Billy Lynch
Fan Motor MOTOR
2910.0
230.0 AC
Here is a Picture of the wiring Diagram that should be on the inside of the rear cover If this is hard to read Here is a link to the original
Jun 27, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I need to find parts for my welder lincoln the fan coolin is not working
Any welding supply house can either get you a fan, or direct you as to where to find one locally.
--W/D--
Feb 19, 2011 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Whats making the fan on my welder not work
The fan motor has probably burnt out, i see this alot...make sure the connections are good....you can try putting 120v to it directly, if it doesnt run you need a new one...if it does then you need to check all your connections
Jul 22, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
How do you wire the old lincoln 225 ac welder
What are you wiring? Power Cord? Fan? Transformer? You should see a white wiring block in the lower right corner if you are looking from the back. On the two top post the black and white wires are attached. The green ground wire is attached to the case. On the two bottom poles the fan lines attach one on each side and the transformer wires that are coming up from the transformer are attached on the same poles as the fan wires.
Apr 27, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
Need the diagram for an old welder, ac/dc 125/225 need to find out how to hook the fan up
Usually the fan if it is, 112/225V. It simply connects across the Line, Phase to neutral, but AFTER the mains switch. So that it is "On" only after the Power has been switched on.
Feb 10, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welder doesnt turn on...
Have you connected the feed from your breaker box to ADJACENT lugs on a dual pole breaker? By code you must use a ganged breaker.
You should use a voltmeter to verify the plug is getting power on teh desired pins.
Sep 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Cooling fan/ lincoln 225 arc welder
the fan should be pulling air from the front of unit and out the back.
Jun 10, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding machine stops working after a few minutes of welding.
there is probley nothing wrong its called duty cycle.which means that if you are welding long periods or welding at max amps the welder will kickout to cool down.Look on your unit for the tag that tells imformation about your unit.It will show something like 30% duty cycle so that means you can weld 3 minutes at full power before the unit shuts down.
Mar 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
895 people viewed this question
Top Lincoln Welding Tools Experts
Jim Goldsmith
Jim Goldsmith
Rob Emerson
Rob Emerson
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
