Question about Presto 05420 FryDaddy Deep Fryer
I need to replace frydaddy cover
Frydaddy cover is split .need a new one
  • 49 Answers
For a replacement cover call Presto customer service at 800-877-0441. Have the complete model number found on the bottem of the unit.
I starts with 054xxxx. Orders are taken with credit cards.
Posted on Jul 07, 2009
  • DEW59 Jul 07, 2009
The lid melted into the grease on my FryDaddy. Is it safe to cook in?
It is probably safe. But why not load up one time with new oil and cook a load of french fries, and then throw the oil and fries away, just to make sure.
Oct 30, 2014 | Presto Kitchen Appliances - Others
My dishwasher hose has 2 splits in it so I need to know how to replace the hose
remove the rear cover and loosen the hose clamp. Pull off the old hose. Put the hose clamp on the new hose, fit the hose to the machine and do up the clamp. Put the rear cover back on,
Dec 20, 2013 | Zanussi 24 in. ZDT6041 Built-in Dishwasher
Need an instruction manual for the Presto Fry Daddy..where can I get one and how much is it?
Your Instructions for the Presto 05420 FryDaddy Electric Deep Fryer can be downloaded from the following site:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000008244.pdf
Thank you for using FixYa!
Sep 19, 2011 | Presto 05420 FryDaddy Deep Fryer
Replace valve cover gasket on 1998 626 i am worried about tearing up the wiring harness that is over the top of it because its brittle any suggestions?
If there is a segmented plastic sheath (flex split loom tubing) covering a bundle of individual wires and it's the protective tubing that's brittle that's normal. As long as you're gentle when handling it even if some of the tubing breaks off it isn't likely to damage the actual wires. Most auto parts stores sell a variety of split loom tubing that you can use to replace the brittle tubing with. The reason it's called split loom tubing is that it is split along it's length so that it can easily be slipped onto wiring harnesses without even disconnecting terminations.
Jan 17, 2011 | 1998 Mazda 626
Frydaddy plastic lid melted. What diameter glass lid might I use to replace it?
I don't have a glass solution, but if you frydaddy is like mine, it has a 7.25 inch dia lid. For about $2 the "Glad Big Bowl" (6 cup size) plastic containers have a lid that fits pretty well.
Jul 15, 2010 | Presto 05420 FryDaddy Deep Fryer
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
How too replace connecting rod on a ttr 125l. I have a 2001 ttr 125 with a seized conn big bearing. and I would like to know the proper way of splitting the crank too replace it
The top end comes off then the left and right side covers, flywheel, clutch and shift shaft. Now a case splitter is used to split the center case halves. To replace the bearing you will need a hydraulic press to disassemble and reassemble the crank halves. If the bearing is seized you should replace the bearing, crank pin and the connecting rod. The crank must be realigned using twin dial gages. Personally, I suggest a new crank assembly be purchased from www.babbittsonline.com ( $241 ). I would replace the crank end bearings at the same time and also the sprocket shaft outer bearing and seal. Please rate my answer.
Jan 03, 2010 | 2002 Yamaha TT-R 125 L
Heater will only run if you take cover off fan. Runs fine until you replace cover, and heater immediately goes out. Filters are clear (have been replaced), what else should I change?
NEED TO CHECK AIR RISE TEMP IT WILL NOTE ON UNE T WHAT THE RISE SHOULD BE EX 45-65 IF ITS HIGHER U MIGHT LOOK INTO COLLAPSED RETURN ALSO AL SUPPLY REGISTERS SHOULD BE OPEV WHEN MEASURING TEMP SPLIT . ALSO TAK A LOOK AT UR HEAT EXCHANGERS BEFORE ATTEMPTING SPLITS AN COLLAPSED DUCT
Dec 26, 2009 | Heating & Cooling
Replacing rear axle dust cover boot on 2005 yamaha grizzly
Inner or outter?? The outter cv joint doesn't come apart. If you rip the outter boot, you need to get a new half shaft. The inner cv joint has a clip inside that you have to take out to split the joint and install a new boot. You also need boot clamp pliers to tighten the clamps or it will come back off first time you ride it.
Jun 19, 2009 | Yamaha XT 660 X Motorcycles
Presto 05420 FryDaddy Deep Fryer Logo
315 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
