Question about Rollei SCA 356 Flash
Connection to Rolleiflex SL2000F SLR
I have a Metz 145CL-4 flash with SCA 300 system, also a Rollei SCA 356 adapter. I wish to utilize the "Auto and TTL" features of the Metz with a Rolleiflex SL2000F SLR camera. The Rollei has no hot shoe, just a X sync. contact socket on the lens assembly. What do I need to be able to use the SCA 356.
  • 1 more comment
  • Vintageplus Feb 19, 2008
    What connections do I need to use the auto setting.
    So I can just use the standard cord I have been using, from the Metz to the X socket on the camera, but instead of setting Metz to the manual mode,(which I had been doing) use the aperature settings on the Metz dial, and the flash will work in the Auto mode?
  • Vintageplus Feb 20, 2008
    Thanks for all your help. I would be using the flash generally in indoor darker situations,
    Weddings, dances, etc.
  • 667 Answers
I checked out a SL2000F that had good pictures on eBay. I see a standard hot shoe on the side of the camera. That being said, neither a standard shoe connection nor a pc outlet will give you TTL on the Metz. TTL is Transistor to transistor logic (or for camera store people, through the lens) A sensor that reads the light from the actual plane of the shutter is required to allow the Metz to give TTL operation. It will work on the Auto setting, but the Rollei does not have the sensor as described.
Posted on Feb 18, 2008
  • Kevin Pettit
    Kevin Pettit Feb 19, 2008
    Either connection will do just fine. The Metz has the sensor for the auto built in. You only need to set the dial for auto. You still have to set the aperture to the proper range ( the scale on the dial of the flash gives you that info) or a hand held flash meter. Easily enough, most shoots do well at 1/60 speed, f8.
  • Kevin Pettit
    Yes, but remember that the sensor on the flash will read any ambient light on your subject. A bright window from behind or a side room light will give some false readings on auto.
I've mislaid my manual for my Metz 54. I haven't used it for a while and can't remember how I set the thing to shoot in ttl with my Fuji S6 Pro. When I'm in ttl mode on the flash the camera doesn't fire....
Not sure what S6 pro is, but if the flash doesn't fire in TTL then the flash is not support the type of TTL in the camera. I had the same problem with Nikon flashes on Nikon bodies. Perhaps you need a newer SCA adapter? Please go on http://www.metz.de/en/photo-electronics/sca-adapter/archive.html to check which adapter you need
Jul 02, 2010 | Metz 54 MZ-4 for Nikon TTL Flash
I got a flash Metz SCA 331, and I use it with Canon EOS Rebel XTi. It works, but I am ''a manual person'' and would like to have the manual for the flash, to learn more and get best performance. I use two...
Metz SCA 331 is the adapter between the camera and the flash. You also need a manual for the flash itself. Google the flash brand, model and add manual to the search.
Aug 23, 2009 | Cameras
Rolleiflex 3003 Battery Pack
where i can find the battery back, for 3003 the batteries can refield
May 28, 2009 | Rolleiflex 3001 35mm SLR Camera
Metz 54 MZ-4i with D70s??
You can get a free firmware upgrade for the SCA 3402 from:
Jhon Salazar
Repair Department
Bogen Imaging, Inc.
565 E. Crescent Ave
Ramsey, NJ 07446
201.818.9500 x 245
service@bogenimaging.com
They handle Metz Flashes in the US
May 10, 2008 | Metz 54 MZ-4 for Nikon TTL Flash
Metz 60-4 flash takes much longer than normal for the ready light to come on to allow me to take another photo.
It is likely the capacitor in the battery pack. If they are not powered up every month, they dry out resulting in long power up and recycle times. You'll need to get it replaced to rejuvenate your 60 CT-4 to its original spec.
Oct 06, 2006 | Metz 60CT-1 Flash
Nikon D70
Many electronics for analog (film) cameras will not work with digital. It is a huge frustration for me. See http://www.metz.de/en/photo_electronics/adapter.143.html -- You may have acceptable performance if you put the flash in "A" mode....Dave
Sep 20, 2006 | Metz 54MZ-4 TTL Flash
Cameras Logo
180 people viewed this question
Top Rollei Cameras Experts
Jax Planet
Jax Planet
james laughton
james laughton
Are you a Rollei Camera Expert? Answer questions, earn points and help others
