Question about Intel PRO/Wireless 2200BG 802.11g/b
Wireless network connection, Intel (r) pro/wireless 2200bg says not connected. How do I get it to say connected? I have disabled it and then enabled it and to my surprise it still says not connected- How can this be?
  • notconnected Feb 20, 2008
    Thanks, I did exactly what you recommended and my internal client adaptor finally changed to connected but for only 30 seconds or so. It would appear that turning my modem and laptop off and then on again connection was much better but not consistent or as good as before. After calling tech support and explaining all of the above, they checked all my modem settings and those Wireless Network Connection settings under properties you suggested and concluded all is functioning as it should. Lastly they told me to right click wireless network connection then click view available networks which in my case should have shown SpeedStream5603 but to our surprise it was blank...i.e no net works were detected. At this point the technician advised that my modem is intermidently defective and has ordered me a new modem. Thanks for your most valuable input...
Very very thanks tom :)
This was very helpful to me
Posted on Jul 22, 2010
  • binojnetwork Jul 22, 2010
    Very very thanks Tom.. :)
    This was very helpful to me....
    Genius:
  • 1,601 Answers
Try these first:
Make sure that the wep password is correct.
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phonesWireless network connection - 1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Posted on Feb 18, 2008
  • Thomas Christopher
    Thomas Christopher Mar 08, 2008
    you are welcome, thanks for the update
My pc crashes when I start a wireless connection using the computer wireless button. Network card is Intel Pro 2200BG wireless LAN. Have reinstalled the driver with no success.
try this...
1. download the updated driver
2. go to the device manager then uninstall the wireless driver
3. restart your computer then reinstall the driver
4. restart your computer for the last time and the driver will be installed properly
Jan 14, 2011 | Intel PRO/Wireless 2200BG 802.11g/b
Wireless connection
you can try to totally disable it, by doing right click of the mouse in top of the broadcasting wireless icon. once is disabled, you can go by START / CONNECT TO / WIRELESS CONNECTION and try again. that should work.
Apr 23, 2010 | Toshiba Satellite M45-S331 Notebook
I have an HP/Compaq 8230 that is 3 1/2 years old. Recently, my wireless has stopped working. "No networks found in range". It is an Intel PRO/Wireless 2200BG.
Do a wireless scan and see how many wireless connections are avaiable in your neighbor. If I was a beating men, that your wireless router is sharing a neighbor's wireless channel number.
Dec 09, 2009 | Intel PRO/Wireless 2200BG 802.11g/b
Describe your Intel PRO/Wireless 2200BG 802.11g/b
SO you are not able to connect tyo the wireless network.
what is the operating system on your computer ?
Click Here for more info wireless connection
Oct 08, 2009 | Intel PRO/Wireless 2200BG...
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
I have an Intel PRO/Wireless 2200BG.... Modem
That is hardware issue ( the modem is bad ) replace the modem and it will solve your issue .
Jul 24, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Intel Pro Wireless 2200BG problem or Linksys BEFW11S4 problem?
I had the same problem. If you are using the latest driver for your intel 2200BG (9.0.4.7). Try to roll back to a previous version. It solved my problems with being unable to connect to a Linksys BEFW11 router running WEP64.
I am now running driver version 9.0.1.9
Oct 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Connects then disconnects.....PLEASE HELP!!!
Every time you click repair on windows the ip address of your network card is changed from your originally set one to something similair to 194.168.x.x, obviously your router will not see your pc after this. You need to connect to your router via an RJ45 lan cable to ensure it is set up properly and enter the settings menu and make sure dhcp is enabled to give the pc an automatic ip address and check that the time out is set at zero, also check your MTU, it should be set at 1493 or 1500, obviously make sure your network card is set to obtain an ip address in the TCP/IP properties. just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 6, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed. Lastly if you have the software that came with the wireless card, dissable it by right clicking the pc network icons in your taskbar and click on enable WZC (Wireless Zero Configuration), as this is a more stable connection to your router and its transfer speed.
May 24, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Intel PRO/Wireless 2200BG 802.11g/b Logo
467 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
