Question about Whirlpool Calypso GVW9959K Top Load Washer
LS shows in the display; machine stops and doesn't respond to reset or to temporarily unplugging
  • drh2w55 May 11, 2010
    After <24 hours, we tried the machine again and it worked. Nothing was done mechanically. Who knows what happened? Thanks for the followup.
  • 15,935 Answers
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
The machine does not respond to any programme. The spin selection display flashes the 800, 600 and rinse stop led's simultaniously. None of the buttons on the machine is responding when pressed or hel
If this is a front loader and there is a pump filter, pull it and clean it out. Mine is located on the front behind a small access door down by the floor. Be prepared for lots of water since your tub is probably full. If it can't pump the water out fast enough (filter plugged) it will become out of balance in the spin cycle and shut down. After you to this unplug the machine for 30 seconds, then plug back in to reset the electronics.
Jan 23, 2015 | Washing Machines
What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
  • PF--Power failure
  • AF--Restricted air flow
  • F01--Primary control failure
  • F02--Keypad/User Interface failure
  • F22--Exhaust thermistor open
  • F23--Exhaust thermistor shorted
  • F24--Inlet thermistor open
  • F25--Inlet thermistor shorted
  • F26--Motor drive system failure
  • F28--Moisture sensor open
  • F29--Moisture sensor shorted
  • F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
Sep 07, 2012 | Whirlpool Dryers
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
1270 e MAKING a shrill sound and screen says parameter init. Had to unplug to make sound stop. Still says parameter init when plugged back in
It may need to be reset.
Please try to unplug it. press & hold the menu/function key while plugging it back in. When lights are blinking release it then press 91. and then display will show parameter init then change to maintenance. Press 99. The display should show date & time.
Hope this helps.
Mar 28, 2011 | Brother IntelliFAX 1270E Plain Paper Fax
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Whirlpool Calypso GVW9959K Top Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De
