Question about Garmin nuvi 260W GPS Receiver
Garmin nuvi 260 does not work when plugged in
How do i get this unit to work when it is plugged in. The screen shows a computer linked to a gps
  • Garmin Expert
  • 343 Answers
I assume you mean when you are trying to plug in to your car?
Have you changed car plug lately?
You have to use a Garmin approved car adapter.
Posted on Feb 23, 2010
I have lost all my maps on my garmin nuvi 255W-
Do a hard reset on your GPS. Download and install Garmin Express from Garmin. Plug your GPS into your computer. The software will identify your GPS and allow you to download new maps to it.
Mar 19, 2017 | Garmin Nuvi 200 205 250 255 260 W
Computer doesn't find the garmin nuvi 260 gps
Download and install the usb drivers from the Garmin site.
Oct 01, 2016 | Garmin Nuvi 250w 255 255w 260 300
Garmin Nuvi 260 Car GPS Receiver
When the charger is plugged into the unit, look at the main menu screen. If the charger is working correctly, the green battery icon in the upper right-hand corner eill go out. If the charger is plugged in and there is a light lit on the charger but you see the green battery icon in the upper right-hand corner of the screen on the main menu, then the unit is on battery power and the battery is not getting power from the charger. Common problem with these units are loose rear USB ports. More information can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 06, 2013 | Garmin nuvi 260 Car GPS Receiver
Garmin gps doesn't work when charging with cigarette charger. Instead of the GPS to Navigate it rather shows like there's a data transfer.
The proper vehicle power cables for the Garmin nuvi 260 are part numbers 010-10723-06 or 010-11478-03.
The use of improper cables will cause the nuvi to go into mass storage.
You may also want to contact Garmin Support for assistance.
http://www.garmin.com/us/support/contact
Sep 23, 2011 | Garmin nuvi 260 Car GPS Receiver
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
I have got a nuvi 260 and it wont come on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Sep 02, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Jan 11, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
272 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
