Question about Weather King 10AJA1801AH Air Conditioner
Please call for manual and orientation of Argentina Thanks
Hi, I'm from Argentina and I have a weather king central air conditioning brought the U.S. and if possible get the manual.
the model is 10AJA1801 outdoor unit.
The indoor unit is model number 14AHJ06S01C01.
A few more of frigories consultita serious? And if you can connect here in Argentina because we use 220 vols.
From already thank you very much.
Sincerely Mauritius
lojacksdad
  • 121 Answers
SOURCE: Weather King 13AJA36A01 AC freezing up at night
check the inside coil is dirtyor may be low on freon
Posted on May 14, 2009
  • 1150 Answers
SOURCE: indoor unit does not function -outdoor unit works
These units have circuit boards inside that have lights on them. These lights come on and tell you what the problem is. I have had 4 units do the same thing that yours is doing. The result has been that the compressor has gone bad. You have to get access to the control board to see the lights. There will either be one inside the inside unit or one inside the outside unit depending on exact manufacturer date.
Good luck and hope this helps.
Posted on Aug 23, 2009
  • 10 Answers
SOURCE: Weather King 10aja1801
The answer is yes however you will want to change the indoor coil in the furnace also.
You would look for a 1.5 ton matched set.
Posted on Jul 19, 2010
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Have you found the problem with ya A/C yet PD with the U4 code, if so what was it.
Posted on Jul 27, 2010
  • 64 Answers
SOURCE: we have a weather king
I would bet the outside units contactor is bad. This is the device where the two thermostat wire connect outside. If this is pulling in/out as you turn the stat on/off then it is working. I just fixed one yesterday with the same symptoms and found the start capacitors were bad. If they are bulged at the top or bottom then they are bad. Good luck.
Posted on Jun 19, 2011
I'm trying to find manuel and info on model #10ajb24a01 its size and ratings weather king central air unit
Hello DDD you got a 2 ton 10SEER unit.Standard efficency rating.RHEEM.com might have the book use the model# .thanks
Jul 15, 2010 | Heating & Cooling
Janitrol Central Air Condition out side unit is not working. When manually press the relay the unit is working, what should I check. How should I check if the realy is getting correct voltage. How to check...
thermostat output to the relay is 24v on the small 18ga. thermostat wires. Is the a-c's coil clean if not look for a high pressure reset button, it looks like a cylinder mounted to the small tubing in the unit with a button on top.
Aug 05, 2009 | Weather King 10AJA3001AH Air Conditioner
My air conditioning unit does not come on outside the fan comes on inside; but the weather king unit itself does not come on.
We need the model and make of your AC.
and please also tell me, How old is this AC?
Thanks
Jun 20, 2009 | Heating & Cooling
Open Questions:
See all Weather King 10AJA1801AH Air Conditioner Questions
Weather King 10AJA1801AH Air Conditioner Logo
95 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
