Question about EliteGroup P4S5A/DX Motherboard
Does this motherboard support ddr 400 - EliteGroup P4S5A/DX Motherboard
    Guru:
  • 480 Answers
No.
Unfortunately your mainboard support DDR up to 333MHz.
You can install up to 2Gb
But it does not suppport Sd-ram and DDR-ram
Posted on Jan 30, 2010
What is the max ram Ican run with a 865pe neo2-p motherboard and
Main Memory
�� Supports bandwidth up to 3.2 GB/s (DDR 400) for single-channel mode and 6.
4GB/s (DDR 400) for dual-channel mode (for 865PE only).
�� Supports two (for 848P) / three (for 865PE) unbuffered DIMM of 2.5 Volt DDR
SDRAM
�� Supports up to 2GB (for 848P) / 3GB (for 865PE) memory size without ECC.
�� Supports only x8, x16 DDR devices.
�� Supports Dual-channel (for 865PE only) DDR 266/333/400 (based on DIMM 1.3).
(For the updated supporting memory modules, please visit http://www.msi.com.tw/
program/products/mainboard/mbd/pro_mbd_trp_list.php.)
Regards.
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
I need to solvthe problem of my new install memory
According to the specs of this motherboard, it supports DDR 333/400 and DDR2 533/400 memory modules. It does not support DDR2 667 memory modules.
DDR 333/400 memory modules can be installed in the yellow slots, whereas DDR2 533/400 memory modules can be installed in the blue slots.
Only one type of memory modules (either DDR or DDR2) can be used. Mixing of different types of memory modules is not supported.
Jul 11, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Replacing existing DDR RAM
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
Upgrade of RAM
184 pin DDR DIMM is the correct information :) The bus speed of the ram would range from PC 2100 - PC 3200. I assume the Max amount of ram will probably be 2gb though unless your motherboard specifies a higher amount.
Mar 22, 2009 | Computers & Internet
Compatible ddr memory for K7AMA Motherboard
2 DDR DIMM Sockets and 2 DIMM sockets support (can not be used simultaneously)
Two 184-pin 2.5V DDR SDRAM (DDR266/DDR200) or
Two 168-pin 3.3V SDRAM (PC133/PC100)
Maximum: 2GB
Jan 03, 2009 | EliteGroup K7AMA Motherboard
Gigabyte GA-8IGX Motherboard memory upgrade
If you bay DDR 400 it will slow itself down to 266 automatically. I've seen a very few cases where it didn't work because of voltage differences but that is very rare and usually with really cheap OEM motherboards, your Gigabyte should be safe.
Aug 11, 2008 | Gigabyte GA-8IGX Motherboard
EliteGroup P4S5A/DX Motherboard Logo
138 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
