Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Gas will not flow. All hoses and filter have been
Gas will not flow. All hoses and filter have been replaced. Husqvarna lawn tractor 21 HP motor.
Check fuel shut off solenoid. If stuck in position cutting off fuel to carb, just cut off tab that closes fuel off. This is only a backfire preventer, but mower should run just fine. No need to replace unless backfiring when shut down!
Posted on Apr 03, 2012
  • 472 Answers
That unit has a fule pump on it thay rarley go out but last week i had one that the pump was frozen it was cold here and i took it off and put in the truck and warmed it up i asllso found a lot off water in the gas tank so try that if that dosent fix it than you may need to get a new one let me know and tell me what moter it has and ill tell ya the part number ok i may have one in stock ok
Posted on Feb 07, 2010
Husqvarna acts like its starving for gas.filter is full.vent hole is clean even does it with cap off.firing even when motor is still hot.run a few mins an die.???
lack of fuel is probably the problem
where from is the question
taking that it is a lawn mower ( husqvarna make a wide range if machinery)
check the hose and filter at the end of the hose at the tank ( inside)
check that there is fuel flowing through the fuel tap as the aluminium type taps corrode inside and block off the fuel
check that there is fuel flowing through the needle and seat when the bowl is removed
check the main jet for blockage
Apr 05, 2017 | Husqvarna Garden
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
Jul 10, 2014 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
What weight motor oil do I put in?
lift hood you will specks usually under hood or around in that area I usually use a good brand 30w oil
Apr 22, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 21 hp mower
check fuel line for colapse near frame rail common problem ? new hose from tank to fuel filter will fix it
Aug 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard start or won't start
the float in the fuel bowl might be getting stuck what you can do is push & pull on float to see if it flows if not the replace the float if i can help further e-mail me wade @ wadembly@aol.com
Jun 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
314 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
