Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon mp-730 print head does not move
After power on, the print head is not moving, the alarm light blinking, 'check printer press resume key' appears on the screen. Press resume key, but no response. The problem started after performing nozzle check.
    Problem Solver:
  • 6 Answers
It seems you open or unscrew the printer.
this may happen if the mother board has no nigative pole.
you have to reset the mother borad.
cannot do that from the available options
the reseting procedure is to take the motherboard out and you have to shortcut the battary for 10 seconds.
re install it , and try it
Posted on Mar 26, 2008
Emty thank
Turn off your printer. Press and hold the "Resume" button, then press and hold the "Power" button. Release the "Resume" button. Press and release the "Resume" button twice. Release the "Power" button. Your printer's print head and ink assembly will start moving and the green indicator will blink. Once the print head stops moving, press and release the "Resume" button three times. Press the "Power" button to finalize the waste ink tank reset process.
Regards,
Ron
Mar 09, 2011 | Canon i850 InkJet Photo Printer
How di I reset the ink counter on a canon mp620?
I found this at fixyourownprinter.com. Seems it works on most mp models and may work on your 620.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Nov 08, 2009 | Canon PIXMA MP620 All-In-One InkJet...
My canon i950 waste ink absorber is almost full
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Mar 17, 2009 | Canon i950 InkJet Photo Printer
Canon MP F60
I had this problem also. None of the reset tricks worked. I replaced the print head with one from ebay and problem solved. Costs around $45 new.
Sep 20, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
LCD Error: "Check Printer"
I FOUND A SOLUTION that worked for me for the CANON F50:
F30/F50 Printer
1. Enter Service Mode - by pressing "menu then copy then #"
2. Select TEST MODE
3. Select (8) PRINTER TEST in TEST MODE
4. Select 3 (EEPROM CLEAR)
5. Select 0 (INK COUNT)
6. Press Stop/Reset key
7. Press On/Off Key
Jun 03, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Canon S900
Category : Printer does not respond, or operate Description : The print head holder does not move to the center
Close the front cover, and check the power lamp indication status (blinking or lighting). List of power lamp indications Blinks in green After lighting in green, blinks in orange 2 or more times Lights in orange Blinks alternately in green and orange, 1 time each this is the option i got on the canon website for printer head not moving to the center. but the light indication given does not match with these options.
It is better for you to go to the above link and see what options suite your problem and follow the instruction given by the manufacturer.
the link is :http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=bj&country=IN.
select your model (i990) then step by step troubleshooting. follow the online instructions.
Jan 08, 2008 | Canon I990 InkJet Photo Printer
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
3. release RESUME
Number of presses - light color - function :
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
Multipass print head stopped working
try to move the printhead left to right. and make sure there is nothing obstructing it. Also make sure you ink cartridges are in securely. If that doesnt work let me know.
Jun 28, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
448 people viewed this question
old marine
old marine
