Question about Mitsubishi VS-6041 60" Rear Projection Television
No power hi. when i push the power button i can hear a relay click but i get no green light for power on.ther is no sound or pickture,i took of the front on the tv and lockated the wire from the light it gose to a add on p/c board on the left main board. i checkt all fuses,OK I think it is a realy problem/bad connection,need some help
    Novelist:
    Champion:
  • 211 Answers
It sounds to me that you have a bad HV/Power Supply Board. Before opening the back of the set, always unplug the set from the wall. If you can check electronic components ( ie: transistors, capacitors, fuses etc ) I suggest you check the Horizontal Output Transistor first. If it's not that transistor, check for cold solder joints ( loose connected parts from the printed circuit board ) and re-solder all bad connections. If the set still doesn't work, you may need to seek professional help, as the problem is more deeply laden and you may need to obtain a schematic to repair the set. I hope this has helped. Good luck on your problem.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
My RCA T19060GY TV/VCR will not stay on. When I push the power button on the unit itself (I don't have the remote.), the green indicator light comes on for two seconds and I hear to click sounds
the clicking sound is due to the relay is getting turn on but doesn't stay because of bad component in the power supply board or in the main board. you must check first the bridge type diode and FET transistor using an analog or digital tester.
Aug 16, 2012 | RCA Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Vizio p50hdtv20a with no picture or sound
sounds like tv shop knows that is missing because they removed it so as not to work when custermer got it back with no charge
Jun 06, 2010 | Vizio P50HDTV20A 50 in. Plasma HDTV
Help required for dumbo on Amps Denon AVR 2808CI
Your unit was probably damaged in shipping. Denon is a nice unit! Do you hear any clicks when you hit the power button??? You should hear two relay clicks. You should hear the power relay click at power on and 3 to 5 seconds later you should hear the speaker protection relay click if your audio amp section is ok. If you hear both relays click then your display circuit is at fault. Open the unit and look for breaks on the front pcb (behind the display) and on the main board in the power section ( where the fuses are ).
Good Luck!
barneyluc
Oct 10, 2008 | Denon AVR 2808Ci Receiver
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Camera problem powering on
I took my battery out, used a pencil eraser to clean off the metal area on the bottom and gently scraped it with a knife. Presto, the camera comes on without having to push down ******* the battery.
Mar 27, 2008 | Nikon Coolpix S50 Digital Camera
Televison & Video Logo
67 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
