Question about Frigidaire Over-the-Range Microwave
My Microwave oven makes a loud buzzing noise and appears as if its about to catch fire with flashing coming from the metal plate located on the right side of the oven. It's model number 7G65005787. Frigidaire Gallery Series. Electrolux Home Products.
  • Frigidaire Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Otherwise, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 31, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
We have model FR185B-CON in our camper, when try to use the oven it makes a loud banging noise. Micowave works fine.
Check the air flow it's probably dirty clogged, don't use it till you find the problem, cuz it could over heat and catch it self on fire. Check the rotating plate inside, skipped gears maybe. Good luck
Jul 06, 2015 | In Microwave Ovens
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
My microwave makes a loud humming noise when it is turned on.
May as well use the microwave as is until it terminates naturally. All microwave ovens buzz, that nothing unusual, but although you can replace a Magnetron, the cost is unusually high. By the time you take the oven down, open the case and fuss around, perhaps not making things any better; the fact is; a new replacement with a warranty is just over $100. Why bother?
Feb 04, 2018 | Microwave Ovens
My microwave is making a loud buzzing sound. Inside the microwave, on the upper right side, is a square area with holes in it. It sounds like the buzzing is coming from behind those holes. Also, after...
THe buzzing noise is most likely coming from the magneton. The magnetron is the main component of the unit (it generates the microwaves). Replaceing it can be very expensive. You may be better off getting a new oven. Prices for new microwave ovens have dropped significantly.
Jun 12, 2011 | Microwave Ovens
My 7year old kenmore microwave 721-62462 occasionally would buzz and flash behind the metal panel on the side of the microwave. This would happen off and on but without any real rhyme or reason. Today it...
ther is a high voltage generator to generate enough power to the magnetron to produce microwaves, it was probably ARCHING voltage to the body of the oven due to a faulty insulator and the paint caught on fire... as for using it well DON'T it is not safe, and will cost more to repare than a new one
Sorry!
Jan 05, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
My MW8108p is flashing and making noises
Do not use the oven! It sounds like the wave guide cover is burned and this poses a fire hazard should you continue to use it. Have a technician look at it and if this is the problem, it is usually a cheap fix.
Apr 12, 2008 | Emerson MW8108P Microwave Oven
Buzzing noise and flashing
Some units have a silica plate covering the waveguide opening. If it get burn spots on it, it'll do that. Remove the plate and try the unit. If it's OK, go to your MW repair shop and order a new plate.
Remember... always cover your food...
Geno
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Loud noise
If you mean a loud buzz that cuts on and off as the oven works, it is probably the outer metal cover vibrating as the magnetron powers up and down. Try holding/ pushing/ poking the metal cover while the oven is working, if the noise abates or goes away, this is the problem.
You may get relief by simply tightening the screws securing the cover, if not, maybe a little careful insertion of a thin strip of cardboard or similar, at the point the vibration occurs, may dampen it. Good luck.
Jan 18, 2008 | Sharp R-254 Microwave Oven
Frigidaire Over-the-Range Microwave Logo
2,420 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
