Question about Dell Inspiron 1501 Notebook
Screen wont light up. can hear windows open but cannot see anything. have tried removing battery and ac and resetting doesn t work
  • therockw Jan 30, 2010
    That did not work, however I heard windows open and after pushing F8 a doinking noise?
    Yes, it helped however i do not know how to do al the testing he recommended so.... still need to take to a tech
  • 10,515 Answers
There are Few Possible Causes. Before we proceed, pull out the Battery Once again and Put it Back ON.
Then, Power ON the Button. Press F8. Did you see any Display?
If not :-
1. You might have Corrupted or Damaged Video Drivers.
2. Do you see any Backlight lit ON? IF not, it would be Bad Inverter Board. You need to replace it.
3. Faulty Screen. Rare but i have seen a Couple of times in my life.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 30, 2010
  • taran_2005
    taran_2005 Jan 30, 2010
    Thanks for the response!!
    I knew that. I have already mentioned 3 Main Reasons for No Display. As you got the Sound, more often it confirms that the Hard Drive, Motherboard is Fine.
    You need to Inspect and Test - Video Card, Inverter Board and LCD Panel.
    Hope i helped you.
    Thanks
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
My hp G60-635DX screen is blank . When i turn it on i cant see anything its just blank screen. I can hear it turn on and if i was to type in my password it would go through and start up jist my screen is...
Try This and see if it resets the whole system
This works for a Sony Laptop.
Remove AC power
Remove Battery
Press the power on button for 30 seconds the release.
Install the battery
Providing that the battery has a sufficient charge, it should turn on. Mine did, and a Sony Technician provided the tip.
Good Luck
Jul 21, 2011 | HP Computers & Internet
Dell inspiron m5030 wont boot up, ac adapter has green light then once it is pluged in light goes out.
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for forty seconds.
Install the battery and ac adapter .Now press the power button to attempt a boot into the OS.
If that doesn't work then remove the hard disk to see if it gets past the splash screen and the BIOS whines that it can't find a boo-table OS. That would indicate a hard disk failure.
Also try to remove the memory module(s) from the DIMM slots and then reinstalling them. That reset the modules and cleans some oxidation off the module pins (if there is any)
Hope this helps.
Let me know if you need more information
Thanks
Apr 26, 2011 | Dell Inspiron M5030 Laptop
I had been using my computer when all of the sudden screen went black and I could hear the windows shutting down. I thought maybe my battery was dead and I was not paying attention, so charged it. But when...
Do a hard reset by turning off the computer and removing the battery and unplug the AC adapter. Without any power source, press and hold the power button and put everything back after. Power on the computer again, if it does not work, try to connect your laptop to an external monitor. If it shows some display it means that the LCD monitor of your laptop has gone faulty.
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
Hp pavilion dv 2000.Screen will not light up and I cannot hear any noise from the drive. Blue lights accross the top all are lit.
Perform the steps below :
1. disconect the ac adapter and remove the battery from the notebook.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. Turn On the notebook
If the issue persists then reseat the memory modules of the notebook and check
This should resolve the issue
However, if the issue persists then it could be a hardware issue. Your notebook needs to be serviced
Jun 09, 2010 | Computers & Internet
My Dell Latitude D620 Screen is Black and the keyboard dosent work when I turn on the computer. The only LED light that shows is the power light, the wifi or the little cylinder light dosent work. I can...
remove all attached devices like printers or flash drives. remove battery and power on using ac adapter only. if it still wont work, try another good ac adapter. make sure ac adapter light is on. if it still shows the power light on and nothing else, replace motherboard.
May 15, 2010 | Dell Latitude D620 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Dell Inspiron 1501 Notebook Logo
19 people viewed this question
Alun Cox
