Question about Dell Inkjet 720 Printer
Replaced both cart and ran test page. got one black line and one yellow at top of page and a little more yellow toward bottom of page -nothing else. Next test page was blank except for some slight yellow.what to do?
Hello.
I turn on the current DX4400, press the button (on) and do not care.
Is food source?
Posted on Jan 30, 2010
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Epson C88 3/16" gap every inch printing black text
Reload the printer drivers, you can get this from the manufacturers web site under support or downloads.
its a common error and an easy fix.
good luck !
Mar 30, 2017 | Epson Stylus C88 InkJet Photo Printer
Have put new cartridges in and only prints yellow lines
Remove all cartridges, make sure any tape has been removed from over the nozzle. Ensure that everything has been installed properly, then use your printer (prompts on device, or in printer>control panel) to print some test pages, realign heads, etc.
May 05, 2011 | Canon Computers & Internet
Colors are not printing correctly. put in a new cartridge, test page came back with only black, yellow, and blue. fiddled around with it a bit to no avail. put in anther new cartridge, test page came...
I use a small diameter silicone tube to carefully "prime" stubborn new carts by sucking a drop of ink out of the tiny print holes in the printhead part of the cart. Ink can dry at the head and since these carts work by electrical excitation, there needs to be liquid of each color at the holes. Slap a drop of water with your finger on the holes to start easy hesitant ones. Do not get the contacts wet.
Jun 04, 2009 | HP DeskJet 932c InkJet Printer
My lg voyager got ran over and you can barely see either screen
Assuming everything else still works, you can buy a replacement LCD screen on eBay for around $50 and install it yourself. The LCD screen comes with the front and inside screen.
Mar 31, 2009 | LG VOYAGER VX10000 Cellular Phone
I have black vertical lines
Black vertical lines could either be a scratch on the drum or a dirty charging corona wire. Order a new drum and clean the Corona with a brush. Image of Corona This should resolve the issue.
Thanks,
ArmyMason
Feb 26, 2009 | HP LaserJet 4050n Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Brother MFC-640CW Replaced Black catridge becomes empty
Compatible carts do make a lot of trouble. One point is the draining! The ink has flown into the cart assy and beyond that to the bottom of the printer. As long as you can print without problems you dont have to do anything. If the test pages wont show the correct color you have to open the printer and to clean the assy and the bottom.
Do use original ink carts though these wont drain and give correct info to printer. You can very simple refill them with dye ink. Dye ink only!!!
Oct 16, 2007 | Brother MFC-640CW All-In-One InkJet...
Dell Inkjet 720 Printer Logo
53 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
