Question about RCA DRC8335
I have a problem with the connection cables (Yellow, White, Red). When I connect them behind the DVD/VCR works the audio; But Doesn't work the Video. Thanks
  • 644 Answers
The cable may be faulty check the cable on another appliance that you know is working, if it is it may be the yellow lead socket has become loose from the board and may need to be resoldered, but check the cable first.
Posted on Jan 30, 2010
I have trouble setting up my 50 inch T.V. It is connected to a VCR/DVD player recorder. I have a red, yellow, and white cable. Do I need anything more?
If possible use a AV SCART connection lead as you get audio & video! If you want to use the phono connection you need to connect all 3 red/white/yellow to the TV and the VCR/DVD! Red & white are audio, yellow video!
Dec 19, 2014 | Televison & Video
CONNECTING DVD/VCR TO CABLE BOX & TV ETC
moz-screenshot.jpgHI-
Check this site for Info's how to connect your device, click HERE
keep me posted for inquiries, thanks!
Jun 30, 2008 | Philips Magnavox DVD/VCR Dual Player
I need help in setting up my VCR player to my DVD recorder
You should be able to connect the video and audio outputs of a VCR (look for a yellow plug labeled VIDEO OUT and a white (or a white and red if it's a stereo VCR) plug labeled AUDIO OUT on your VCR to the same colored jacks on your DVD recorder labeled VIDEO and AUDIO IN. You'll need an RCA patch cable that has yellow, red, and white plugs-they're readily available at just about any store that sells electronics (Walmart, Best Buy, Target, etc.) and should cost less than $10. Don't let them upsell you to the expensive cables-you're probably not going to notice a difference.
Once you're hooked up, just hit "play" on your VCR and "record" on your DVD recorder, and you should be good.
Dec 29, 2012 | Televison & Video
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Aug 19, 2010 | Zenith Televison & Video
Trying to connect vcr/dvd to tv. Do not have
you need to have your basic rca cables (yellow, red and white). The cables you are referring to are composite cables and if you do not have component inputs on your tv they will be useless. You can use rca cables on any tv that has video.
May 15, 2010 | Televison & Video
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
RCA DRC8335 Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
