Question about Samsung Refrigerators
Manual for samsung model rs2577sw power to lights, but not to computor controlling tempatures for freezer & refrig.
fridgetech
  • 473 Answers
SOURCE: I NEED TO DOWNLOAD OR OBTAIN THE OWNERS MANUAL FOR SAMSUNG REFRIG./FREEZER MODEL RS 2630 WW
Go to http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=rs2630ww&modelid=294604.  Part # is OMRS2630WW and cost is $13.00.
Posted on Oct 26, 2007
docjohn174
  • 943 Answers
SOURCE: freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Posted on Oct 17, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Refrigerator won't cool less than 52 degrees
I can tell you if it can be fixed by you or if you need service. Just answer a few questions as we go through this. Pull away from wall and remove the lower panel. Feel top of compressor and see if too hot to keep your hand there or cool. Let me know if freezer fan and fan below are running. Answer those and that will help me answer your questions, Thanks Sea Breeze
Posted on Feb 16, 2010
  • 39 Answers
SOURCE: GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Posted on Dec 06, 2010
ginko
  • 19396 Answers
SOURCE: 7 1/2 yr old Samsung frig RS2577SW overnight
Hi.
The problem is usually a defective defrost control or defrost system, in some case the temp control may be faulty. The defrost system causing the problem is far more common.
If this model has a temperature sensor for the freezer, check also the sensor.
About the problem:
If the unit is cooling down regularly and then going off after about 8 hours, then it is the defrost timer. The part must be replaced.
If there is ice on top of the evaporator coil, then the problem is still defrost system. Defrost timer, defrost thermostat, heater element and fan must be tested.
If the unit is not responding, and the temperature is changing erratically, or the fridge is not working at all,then the problem can also be the temperature control. This basically means that the electronic control board located in control assembly (behind the panel where you set the temperature) is defective. The part is difficult to test.
Start disconnecting power overnight. This will allow full defrost and will also reset the electronic control. If the next day the fridge and freezer sections are working, then the problem is the defrost system (AKA evap). The problem will restart in one or more days, when the defrost system failure starts putting the condenser under stress.
Here below a short article I wrote some time ago. It shows how to do the repair on a Kenmore fridge. Part location and some part name will be differently, but it is useful to understand how repair is done (it explains how to test parts): When the fridge is not cooling ...
Here parts and diagrams for this model: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Refrigerator-Parts/Model-RS2577SWXAA/1482/0165000
Posted on Jan 22, 2011
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
The tempature on my refrig. panel continues to blink on the frig.side. I have it at the lowest settinng which is 34F. The Freezer has not moved nor is it blinking. The freezer is still holding its temp. ...
The computer has detected an error in the system and needs to be addressed by a Samsung qualified technician. They have a list of error codes that they can figure out what's wrong with the unit.
Jul 18, 2011 | Samsung RS2630SH Side by Side Refrigerator
Hi, I have a RFG295AAWP refrig. My son leaned
HI,UNPLUG THE UNIT FROM POWER FOR 5MIN THEN PLUG BACK TO POWER TO SEE IF THAT HELP BUT IF DON'T GO BACK TO NORMAL,CHECK IN THE BACK OF THE BOX FOR FACTORY TECHNICAL INTRUCTION SHEAT YOU MAY FIND THE ANSWER THERE..
Jul 05, 2011 | Samsung 25.8 Cu. Ft. Side-By-Side...
Feb 15, 2010 | Maytag Admiral Top-Freezer Refrigerator
My side by side Model GSH22KGRE BB freezer is
there is one of 2 possibilities,either the damper door between the refrige and freezer compartments is frozen shut due to ice build up and needs thaw out,the cold control that controls this door is bad or the mother board on the lower rear apron behind a cover panel is defective,if you have had light bulbs go out in the refrige compartment and now the refrige part does not cool and the temp light readout is dark this is a good indication its the motherboard,also if the lights are strobing and you can hear a relay clicking
Jan 17, 2010 | Refrigerators
I want a manual for a samsung refrigerator model number RS2577SW
you should be able to go to www.samsung.com and go to mauels in order to find this if that does not work i think i can email you one
Sep 17, 2009 | Samsung Refrigerators
Refrigerators Logo
60 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
