Question about Weiser Lock Powerbolt 1000 Lock
Bolt does not extend or retract. Have replaced the batteries but it still doesn't work
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 165 Answers
Maybe the connecting wire tape has come loose or gotten damaged.
Posted on Mar 02, 2010
Replace a rear seat belt in a 2003 mitsubishi magna
try loosing of the belt mounting bolt and moving the unit around . The lock mechanism may release and allow the belt to rewind
Feb 15, 2015 | Mitsubishi Cars & Trucks
Interior door lock won't lock with twist
If the bolt extends fully when the door is open, the problem is with the strike hole in the door frame. (If the bolt doesn't extend when the door is open, it's either a bad installation or a bad lock. Read the instructions again and reinstall it or get a new lock.)
If it used to work, open the door and tighten all the hinge screws before you do anything else. They could be loose even if they are covered with paint. This solves about half the problems with doors and locks.
The easiest way to figure out where the strike hole should be is to use the "lipstick trick." Extend the bolt with the door open, and scrap a tiny ridge of lipstick on the top, bottom, and both sides of the bolt so the lipstick will hit the doorframe before the metal of the bolt does. Retract the bolt, close the door, and try to extend the bolt a few times so the lipstick leaves a mark on the edge of the hole or somewhere inside the hole. Retract the bolt all the way before opening the door so you don't smear any marks on the frame. Now you can see where the problem is and what needs to be moved, or filed, or cut deeper.
Every woman who wears makeup has lipstick she bought and cannot return to the store. She will be glad to give you a tube and get some use from that awful color.
Mar 16, 2014 | Kwikset Locks & Locksmithing
Removing a kick Stan on a Harley a 1990
Jack bike so it won't fall over when the kickstand is removed.
Move kickstand half-way between extended (down) and retracted (up).
Remove pivot bolt nut, washer.
Remove pivot bolt.
Unhook kickstand spring.
Mar 01, 2014 | 2000 Harley Davidson FLHTCUI Electra Glide...
Lens on my S7000 doesn't retract when switched off - now permanently extended - and camera dead
This is going to require service / repair at the shop, not something you will be able to correct.
Jan 26, 2013 | Fuji FinePix S7000 Digital Camera
Replaced battery & pcv valve now speedomter
Under the battery tray is a common ground point. It'll have several black wires going to a connector that is bolted to the frame. Remove this bolt, clean the area up, and bolt it back in place. If the speedometer doesn't work after this, then you probably need a vehicle speed sensor VSS.
Sep 13, 2011 | 1998 Ford Escort
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Lid won't lock when going to wash.
Door Lock Failure
dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from
extending.
Machine/motor control detects open door lid switch when
attempting to lock.
Machine/motor control cannot determine if door
lid is in a locked state.
Door Unlock Failure F-83
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state.
Sep 17, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Dimage Z3 lens does not retract
Check your batteries. Are they working? Try taking them out and replacing them. If you left the camera on when you put it away and the batteries drained, you won't be able to retract the lense until fresh batteries are inserted and the camera is powered up again.
Feb 02, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
FE-170 - Lens extends & retracts 3 times when powered on.
appears to be power issue in the camera but you can try the lithium AA batteries that are located in the photo section of your stores... they are more powerful than regular AA batteries or else send to repair shop
Dec 04, 2008 | Olympus FE-170 Digital Camera
Weiser Lock Powerbolt 1000 Lock Logo
424 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
