SONY 1993 53" PROJECTION TV HAS NO AUDIO OR VIDEO OR BLINKING LIGHT. WHAT DO I CHECK AND IS THERE ANY SONY SUPPORT? KPR-53EXR15
    Novelist:
    Champion:
  • 211 Answers
It sounds as though you have a damaged the main board ( power supply board). First I would suggest you check the fuses, in both the main board and also the convergence board ( there are two main boards in your set ). Before you start, always use caution by unplugging the set from the wall. To check the fuses, remove the bottom panel cover in the back of the set by removing the screws. Use a flashlight and observe all the fuses you can find and see if any are opened or burned out. ( if the fuse is burned out, it will be black, you may not be able to see if the fuse is just opened without using a continuity checker ( volt ohm meter ) ). Any fuses you find open or burned out, replace with a like fuse ( voltage and amperage ). The set should work fine if a fuse is the problem. If the set doesn't have a bad fuse or won't work after replacing a bad fuse, then you will probably have to seek professional help. Check www.sony.com for service in your area. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Posted on Feb 18, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Sony KPR-53EXR15 pictures fades in and out
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
Mar 31, 2017 | Televison & Video
No Video/Sound,POwr Gren LiTE Blinks 4Ever, SONY WEGA KDF-55WF655
Please check lamp in tv as pop sound seems broken lamp.
Did you replaced lamp in last 2-3 years in tv? If not, then its lamp that got broken and tv needs new lamp.
Lamp replacement procedure is written in user manual and its easy, please buy Sony original lamp for good picture in tv.
Thanks.
Apr 25, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kpr-46cx10 picture issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Televison & Video
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Old Sony KPR-53EX35
If you have snowy picture on this TV set, the problem is not your high voltage transformer,
The defective part is more likely the tuner or the IF section of the TV.
I would suggest to use a video source from a DVD player ot VCR and connect the audio & video output to the audio & video input on the TV. Do not forget to select video 1 or 2 on the TV.
Hope this helps.
Feb 15, 2008 | Televison & Video
SONY KPR-46CX35
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 15, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
