I using windows XP, and the when it gets to the windows login screen (where I choose which name to start windows in), the monitor suddenly cuts out with the message, "no signal input." The weird part is the computer boots fine in safe mode. Thoughts?
  • 581 Answers
It could be one of several things such as:
Loose cable, or bent pins on cable.
Loose video card.
burnt out power for the video card chip on mainboard (smells bad).
Video card is dead.
Remove the monitor cable from the Video card (back of PC),Open your PC case, earth yourself by touching the casing then see if the video card is loose, if so push it in. If not take it out anyway and put it in again, blowing the dust away (or even better use a vacuum cleaner to vacuum all the dirt out of your PC). Make sure it sits correctly.
Put the cable back on making sure it fits tight and that no pins are bent, and turn it on.
If this doesn´t work then try a different video card, even an old one. IF this works your video card is faulty.
Posted on Jan 30, 2010
I have the notebook PC x551 and when I tune it on
Have you try safemode? After the pc starts start pressing the F8 key.
Choose safe mode and see if you can login and see the desktop. If you do then in safe mode run anti-virus software. If you use Windows XP see if you can login as "administrator". Your profile could be corrupted. For vista, Win7 requires other method dificult to explain to login as administratore.
Sep 12, 2014 | Computers & Internet
Tip
Three simple ways to recover Windows XP password
<p><a><span>This may happen when you attempt to log in to your Windows XP and you realize you lost the password. Just because you can't remember or some hackers had change your password.</SPAN></A><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>It's easy to gain access to Windows after losing user account password. Just simply login as the computer administrator and go to control panel-&gt;user accounts. There you will be able to reset the password for any of the systems user accounts.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Howerver, things will get more tricky if you have <b>lost Windows administrator password</B>. It's a sickening,powerless feeling to be locked out of your own computer though this happens more often,everytime we feel so helpless.What should you do in facing this situation.You have tried everything you could but failed.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><a><span>This problem of<b> Windows XP password recovery </B>often troubles most PC users, especially for those who have little computer skills. For this, </SPAN></A><a><span><span>following are three simple ways on how to </SPAN></SPAN></A></SPAN><a href="http://www.lostwindowspassword.com/"><span><span><span><b><span><span> </SPAN>recover Widows XP password</SPAN></B></SPAN></SPAN></SPAN><span><span><span></SPAN></SPAN></SPAN></A><span><span><span><span> to help you login your computer again.</SPAN></SPAN></SPAN></SPAN><br><span></SPAN><span></SPAN> <p><span><span> </SPAN></SPAN><br> <p><span><b><span>Method 1:<span> </SPAN>Login as Safe Mode</SPAN></B></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Start system and press F8 key when Windows is starting up. Then select Safe Mode with Command Prompt and enter. Choose Administrator,the default password may be blank if you don't set the default administrator password before.Then you will enter into doc Command as following.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Type " net user net user xxx 12345 /add " (xxx is the locked account name and 123456 is the new password set on this account).Then you will see the Command Completed Successfully.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><b><span>Method 2: Using A password reset disk</SPAN></B></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Windows XP and further versions also provide another method to recover forgotten password by using ""Reset Disk"". If you created a Password Reset Disk in past, you can use that disk to</SPAN></SPAN><a href="http://www.lostwindowspassword.com/"><span><b><span> recover Windows XP password</SPAN></B></SPAN><span></SPAN></A><span><span> as follows. </SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Step 1: Start Windows and click your username when you get to the Windows XP logon screen. Type the password wrongly.</SPAN></SPAN><br> <p><span><span> </SPAN></SPAN><br> <p><span><span>Step 2. Press Enter and you will see the error message about "Did you forgot your password?</SPAN></SPAN><span><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: &#23435;&#20307;; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman
on Jan 04, 2011 | Computers & Internet
Tip
It's easy to gain access to Windows after losing user account password. Just simply login as the computer administrator and go to control panel->user accounts. There you will be able to reset the password for any of the systems user accounts.
Howerver, things will get more tricky if you have lost Windows administrator password. It's a sickening,powerless feeling to be locked out of your own computer though this happens more often,everytime we feel so helpless.What should you do in facing this situation.You have tried everything you could but failed.
This problem of Windows XP password recovery often troubles most PC users, especially for those who have little computer skills. For this, following are three simple ways on how to recover Widows XP password to help you login your computer again.
Method 1: Login as Safe Mode
Windows XP and further versions also provide another method to recover forgotten password by using ""Reset Disk"". If you created a Password Reset Disk in past, you can use that disk to recover Windows XP password as follows.
on Dec 23, 2010 | Computers & Internet
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
I found a laptop Dell Latitude D600 which has windows xp professional. It is requiring me to login with the previous user's information. I do have Windows home edition disk to install, on this laptop, but...
reboot the computer as soon as you turn it on press F8 KEY once every second till you get a black screen saying
safe mode
safe with networking
ect ect choose safe mode
log on as Administrator
go to control pannel ... user accounts
select the name and remove password reboot
Dec 28, 2009 | Microsoft Windows XP Professional With...
Tip
Remove User Accounts from the Login Screen in Windows XP So you login to your...
So you login to your computer every single day, but there’s morethan one account to choose from… either because you got the computerfrom somebody else, or some software package added a user account thatyou really don’t want to see. So how do we hide that other account fromthe login screen?
There’s a simple registry that you can do to hide accounts fromthe login screen, or you could alternatively delete the user account ifyou really don’t need it. Both methods are listed below.
Open up regedit.exe through the start menu Run box, and then navigate down to the following key:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NT
CurrentVersionWinlogonSpecialAccountsUserList
On the right-hand side you’ll see a list of keys that correspond touser accounts that are considered “Special” and are not to be shown onthe login screen
Create a new DWORD value with the same name as the user name thatyou want to hide. You’ll note that the actual username in theillustration was “OtherPerson” and not the description that was shownon the login screen.
To unhide the account, simply delete the registry key that you created.
The next time you log off you’ll see that the other account is gone.
Hide User Account with Tweak UI
You can also use the Microsoft Tweak UI PowerToy to do the same thing. (Thanks to Gustav for reminding me to include this)
Just click on the Logon key in the left hand side, and then uncheck the box for “Show <username> on Welcome screen”
Login to Hidden Account
You can still login to the account even though it’s not shown… You’ll just have to use a little trick.
At the login screen, just hit the Ctrl+Alt+Delete combination twicein a row, and you’ll be presented with the old-school login screen,where you have to manually enter the username.
Type the name and password of the other user, and login.
Delete User Account
Alternatively you can always delete the user account if you areabsolutely sure that you don’t need that user account anymore.Right-click on “My Computer” and choose “Manage”
Navigate down through “Local Users and Groups” and then Users, and thenlocate the username in the list that you’d like to get rid of.
Just right-click and choose Delete. Note that this step cannot bereversed, so make sure you only delete accounts you really really don’twant anymore. If you are unsure, you can just hide them using the firstoption above.
on Jun 24, 2010 | Computers & Internet
Tip
13 Steps to Change or Recover Windows Administrator login Password in...
Have you lost your Windows XP administrator login password, and you don’t know what to do? Here are thirteen simple steps that you can use to change or recover administrator login password of your Windows XP computer.
  1. Insert the Windows XP CD in your CD / DVD drive and restart your computer with him. To do this, after ensuring that established the system BIOS to boot from the CD as first choice. Check your system BIOS to see what is more.
  2. a “Press any key to boot from CD or DVD” message is displayed, press a key to boot from the Windows XP disk.
  3. Windows Setup will now inspect your system and load the required files.
  4. On the “Welcome to Setup” screen, press Enter to start Windows Setup.
  5. Scroll down the Licensing Agreement screen and then press F8 to accept it and proceed further.
  6. On the Setup screen that is displayed next, you may get an option to repair Windows. Select the Windows XP installation you want to repair and then press R to start the Windows repair process.
  7. During the repair process, Setup will first check the disks on your computer and then start copying the required files. This task will take a few minutes.
  8. After the files are copied, you will be asked to restart the PC. If you don’t, PC will restart automatically after 15 seconds.
  9. When the PC restarts, don’t choose to boot from CD. Setup will automatically resume and you will see a message box informing you that the Windows installation is on.
  10. During this process, you need to keep an eye on the left had panel of the screen that informs you about the setup status. When you see that the “Installing Devices” task is in progress, press the Shift + F10 key. This will open a Command Prompt window that you can use to perform several admin tasks on your computer. Surprised! Well, yes the world’s most popular operating system does have a few security loopholes.
  11. At the command prompt, type NUSRMGR.CPL and then press Enter. The User Accounts control panel window will display.
  12. In the User Accounts window, you can perform various user management tasks, such as, reset passwords, change password, create new user, and configure no password login. After making the required changes, close the dialog box, exit the Command Prompt window and then proceed with the repair process. You may need the Windows XP product key, so keep it handy.
  13. After the repair process is complete, you will be able to log on to your Windows XP computer using the new password you set during the repair process. In case, you choose not use a password, you will not be asked for one.
This process will not have any affect your existing programs and personalized user settings. However, if you find this method to change or reset administrator password in Windows XP complicated, you may opt to use a reliable third-party tool, such as Windows Password Recovery Tool .
This is a real handy tool that enables users to perform several Windows recovery tasks, such as recover passwords, make and restore data backup, manage partitions and recover lost data.
aiosp_title=13 Steps to Change or Recover Administrator login Password in Windows XP
aiosp_keywords=windows xp password, xp password, xp administrator password,windows xp administrator password,xp login password,windows xp login password,recover xp password, change xp password, reset xp password, bypass xp password, crack xp password
aiosp_description=Have you lost your Windows XP administrator login password, and you don?t know what to do? Here are thirteen simple steps that you can use to change or recover administrator login password of your Windows XP computer.
aiospwlwbsend-->
on Apr 01, 2010 | Computers & Internet
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
LCD not being detected
Restart computer -> Keep tapping on F8 key till safe mode option appears-> login using safe mode -> when login complete -> rightclick on my computer -> properties-> hardware tab -> Device Manager -> click on Sub-option "Display Adapters"-> Right click the adapter inside -> properties -> driver tab -> rollback drivers.
Follow instructions and restart and choose normal windows if asked.
If not successful, goto start -> all programs -> Accessories -> System tools, -> system resore -> choose restore to a previous... -> choose a date before the date you updated drivers. dont go 3-4 month, you might loose data. choose a closer date to the date you found the issue. follow the instructions.
restarts automatically and recovery screen comes. dont worry this is normal. when done, restart the system and see if resolution is alright.
get back to us with what has happened, we will support you further.
thanks, have a nice day....
Sep 16, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Change wellcome screan of windows xp
Disabling the Windows XP Welcome screen.
  1. Click Start, Settings, and Control Panel.
  2. Open User Accounts.
  3. Click "Change the way users log on or off".
  4. Uncheck the "Use the Welcome screen".
  5. Click "Apply Options"
Disabling the Windows XP login prompt for password.
Click Start and Run
  1. Type "Control Userpasswords2" and press enter.
  2. Uncheck the box for "Users must enter a user name and password to use this computer."
  3. Click Apply and Ok.
Jun 09, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
