Question about Zenith Z50PX2D 50 in. Plasma HDTV
User states she locked the sys n dont remember the code
Need a work around for a locked sys,or the correct jumper settings to unlock the system
    Sniper:
  • 67 Answers
Http://136.166.4.200/contents/Displays/PDP/50/Z50PX2D/Service_Manual.pdf
Posted on Feb 22, 2008
I have a dell 3000 dimension desk top computer. The message I get after tapping the F12 key is as follows. Key board failure. Type password and press enter to leave password security enabled next line
The motherboard BIOS is activated when you press the F12 Key and can be locked via a password that is different from your pc user account. There is only one way to reset this because the BIOS is a chip on the motherboard. You have to reset the password using a jumper on the motherboard that is marked with PSWD. This will also clear the CMOS which is Computer Memory on Startup which tells the computer the different changes from the original bios chip. so you may have to go in and set some settings in the bios to have everything back to operational.
Turn off and unplug the tower before opening it.
The password jumper's location on a Dell Dimension motherboard can be found by reviewing the Dimension User Guides.
For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Now replace the panel and plug unit back in. You should be able to enter the bios without a password.
Oct 01, 2014 | Computers & Internet
96 ford explorer power locks or windows not working
On a 96' Ford Explorer XLT (like mine) the code is in the trunk of the truck behind the plastic cover where your tire jack and wrench are! There will be two plastic knobs that you will have to turn to open and lift it off, real simple. The code will be on the fender wall, bring paper and pen to write and will need a flash light so you can see the code clearly.
The code is real close the the plasic and kinda hard to see. Hope this helps! If you dont see the above,then try looking around in that area for a 5 digit code, in the fender well or around the jack, or even around the rear washer bottle. Most people have said its around the jack.
Hope this help (remember comment and rated).
Apr 04, 2010 | 1996 Ford Explorer
Set key code
on the 3240 you will need to have a jumper installed to remove the key counter. this is a hard setting not a softsetting. you need to remove th inside front right cover. under the cover is a 4 pin clear connector. you need to reinstall the jumper to tell the machine no keycounter is installed. the jumper should be under the cover
Sep 25, 2009 | Gestetner Copier
Im locked out of my phone i dont remember my security code
Try the last 4 digits of your phone # and if that doesn't work call up the place that you purchased your phone from and they should be able to help you out.
Jul 31, 2009 | LG ALLTEL AX275 Cellular Phone
I dont remember the phone lock code of motorola v3i
Your phone’s four-digit lock/unlock code is originally set to 1234.
The six-digit security code is originally set to 000000.
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the
last four digits of your phone number. If that doesn’t work, press and enter your
six-digit security code instead.
Jun 24, 2009 | Motorola Mobility RAZR V3i Cellular Phone
How to hard format 6300
If it would SIM lock then you could get the PUK code and unlock it. If it as phone lock then remember the correct unlock code and try it after some time. Dont try it continuously. If you try continuously, if it's correct code also it won't work. The second solution is to reloading the software in your mobile. This may erase all data in your mobile. you may reload this in any mobile service centers. This method has to work. Thank you
Sep 06, 2008 | Nokia 6300 Cellular Phone
I locked my motorola K1m and forgot the unlock code and now i cant get into my phone.
If it would SIM lock then you could get the PUK code and unlock it. If it as phone lock then remember the correct unlock code and try it after some time. Dont try it continuously. If you try continuously, if it's correct code also it won't work. The second solution is to reloading the software in your mobile. This may erase all data in your mobile. you may reload this in any mobile service centers. Thank you
Sep 06, 2008 | Motorola Cell Phones
Parental control lock
Here is the user manual, check page # 40 on how to clear the secret code.
Mar 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
52 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
