Question about Philips SBP1100/37 Portable Speaker System Computer Speakers
Connecting speakers I am trying to install the portable philips PC speakers (SBP1100) and I am getting no sound what did i do wrong?
  • Anonymous Aug 25, 2008
    They don't work --- tried EVERYTHING (yeah, even the stupid, obvious stuff).
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello there!
First things first!
1) Connect the speakers to out on PC, press carefully .
2) Go to control panel and see on multimedia , that sound is enable, and not in mute. pop up volume.
3) may be is defective speakers? go and RMS the Speakers, if got warranty or change for another.
4) Good Luck!
Posted on Feb 25, 2008
I am not sure I have my speakers connected correctly. I connected into a port on the back of my tower, but do not know where to connect the little plugs from the speakers. I am not getting any sound
the plugs usually red green and black/blue if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any sound settings by right clicking on the speaker icon
then you are ready to position your speakers if you have more than 2 you might need to select stereo
hope this helps
Jul 30, 2011 | Philips SBP1100/37 Portable Speaker System...
Why is it that only one of my Philips speaker is working on the right side, but not on the left side speaker (no sound coming from it at all) after plugging into the USB port of my ACER laptop computer...
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 15, 2011 | Philips SBP1100/37 Portable Speaker System...
Computer will not recognize Philips Portable Speaker System SBP1150.
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers if you have tried this you might try
control panel,administrive tools,computer management,device manager,sound,right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 28, 2010 | Philips SBP1100/37 Portable Speaker System...
How to install philips portable speakers to my hp computer
use a multi-out jack....it will have two out jacks(female) and one pin(male) to be inserted into the audio out jack on the computer, connect your speakers pins(male) to those 2 out jacks....
look for this.....buy it on ebay look for "Audio Spliter"
guess this helps...pls let me know leave a feedback for this solution...
reg
Apr 27, 2010 | Philips SBP1100/37 Portable Speaker System...
The sound is to low it seems that the speaker
check your Sound audio option in Control Panel....
check your audio jacks and cables for any cable faults...
check the volume control
Dec 10, 2009 | Philips SBP1100/37 Portable Speaker System...
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Very very low sound/output
Helle there!
First!
1) check your setting for sound to (2 way speakers)
2) Setting for Volume in control panel.
3) connector may be you need a little expantion from radio shack gold ext.
4) be sure you got sound from headphones !! **
Go it!
Jul 31, 2008 | Philips SBP1100/37 Portable Speaker System...
Very low output
Are the Philips speakers powered ????
Try in the headphone socket on a radio and check the sound then.
My Philips SBP1100 speaker' volume is not loud enough
Were they ever loud? If they weren't (which is my guess - judging by the picture) is that they are low wattage which essentially means that they are not intended to be loud. They are most likely to be used as a small compact, low-noise speaker for a smal MP3 player where high (club-vloume) wattage/volume is needed. If they used to be loud check the volume control on your laptop and check each and every setting that there is. One stupid little setting could be a big difference. Audio Properties in the control pannel could be helpful but don't mess with those settings in the control pannel unless you are almost positive as to what they are and what they do. You could cause yourself a bigger problem. Remember that most laptop speaker outputs are actually for headphones and are not intended to go super-high as they are designed for headphones and not to hurt ears at high volumes. Hope this helps. If not try checking back with me. Best of luck. Bonne chance!
Mar 09, 2008 | Philips SBP1100/37 Portable Speaker System...
Philips SBP1100/37 Portable Speaker System Computer Speakers Logo
320 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
