Question about Sony STR-DE845 Receiver
Hello! I just hooked this receiver up after some time sitting in the closet and it works for less than a minute and then the sound switches to the TV and PROTECTOR flashes across the Reciever screen? I checked my wiring and it all appears to be hooked up properly. The only difference I can see since the last time I had it hooked up is I have an HDMI cable coming out of the receiver to the TV but I have the fiber optics cable running from the Blu-Ray player to the receiver
  • cinematichd Jan 30, 2010
    I think I have it working now. One thing still puzzles me though. The blue light for the receiver letting you know it is a 5.1 surround sound is not lighting up when I am playing the Blu-Ray player? I'd love to get this set up so the blue light was "ON" on the receiver so I knew I had Dolby Digital 5.1 Surround.
    The apparent fix could have been a number of things but here is what I did.
    1: I went to each speaker and shortened the exposed wires to 1/2" and made sure they were all inserted proper and not touching.
    2: I did the same thing for the speaker wires at the receiver end.
    3: I reversed the RCA connectors where they plug into the receiver just in case I had them plugged in to the wrong polarity.
    4: I went into the TV menu and shut the audio off on the TV so all the sound must come through the receiver now.
    I am thinking that because I had the Blu-Ray player hooked to the TV with a HDMI cable (for video) and then had a Optical cable running from the Blu-Ray player to the receiver for the audio signal that something was going one with that.
    President:
  • Sony Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jan 30, 2010
  • Frank Fulton
    Frank Fulton Jan 30, 2010
    Just make sure that you have the "Audio Input" selection set to "Digital" There is either a button on the front of the receiver or a menu setting in the "Setup Menu" for audio input "auto/digital/analog". When there is a "Digital" signal being sent digital will be played. Look at a DVD case and look for the audio section as to how it was recorded, then play it. Check for the "Digital" light. You should be fine. Hope this helps.
How can I get my Denon 2106 to play through my television? I'm not sure what's happened. I feel like I have the cables hooked up properly. It's worked for years. My stereo plays, so it's not the speakers....
Hello: If you are trying to get the sound from the TV to come through the receiver to your speakers and are hearing nothing, I had the same problem. For some reason, and I have the question posted, the sound level requirement is much higher for the TV. I turned my receiver up to +2 decibels and the sound was there. However, if you play high def channels through the receiver, the +2 will blow your ears off. My new problem is why does the regular TV need so much volume on the dial while the high def channels only require the lower sound level. It prevents you from switching from regular to high definition channels. So, in summary, the sound is there, just turn the volume way up.
Oct 30, 2010 | Denon AVR-2106 Receiver
I am replacing a 50' run of RG-6 Quad Shield cable from my central box in a closet to a wall jack. I am simply unplugging the current run because the jack is in the wrong place and replacing that run with...
Hello, I am a Dish Network technician.
The most likely reason you're having this issue is may be some type of switch between your closet and your TV jack, that you're bypassing when you install the 50' lead. Your best bet will be to schedule a technician to come for a visit, we have the tools and training needed to find and eliminate your issues with ease. Most likely, this is something that the average person won't be able to tackle.
Aug 22, 2010 | RCA DISH Network(r) 311 Satellite System
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
Wesitinghouse 37" all of a sudden wont work with hdmi cables plugged in. only picture with component cables in. ps3 wont work individually either currently have it directly into cable source and everything...
Same problem I had... My problem was with any HD input from PS3 (only HD device I have), the PS3 was fine on other televisions so I determined that it must be a problem with the TV in question. I fixed this problem by unplugging the TV, letting it sit for about a minute and then plugging back in.
Apr 13, 2009 | Westinghouse LTV-37w2 HDTV
Have att uverse receiver in bedroom hooked to a Sharp Aquos LCD TV. The ATT remote works fine with the tv, but it does not work with the ATT receiver box. Tried switching remotes and receivers from...
Read in other forums that some lcd tv may interfear with infarated signal....I didn't know this when i had my problem had to put my reciver inside closet away from tv for it to work......
Mar 14, 2009 | Denon AVR-1908
Electronic eye on tv does not capture remote rw
hello if you already changed the batterries you problably drop it or sit on it you better take it for repairing saludos
Nov 20, 2008 | Denon AVR-2807 Receiver
Sound cuts out- cable tv
I had the same problem when I installed the new HD Comcast cable box (DCH3200), initially with my CRT through RF, then with my HDTV through HDMI. Problem solved when I replaced the box with the Comcast RNG110 I got from my local Comcast. It is a neat miniaturized box and it works extremely well on HD. There is no power switch on the box so before activation do not forget to put it on with the remote (cable, power, the green light will come on).
Aug 09, 2008 | Sony STR-DE595 Receiver
Digital Optical input on receiver doesn't work
You have set the TV and receiver up to use the optical output? Both should have settings that can switch the sound through the optical on or off.
Set it to Dolby Digital for example!
Mar 08, 2017 | Audio Players & Recorders
Tv shuts off
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times. during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section. if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2. if set is old then there is a possibility of crt getting weak. but if the above things are not there then problem in power supply. good luck
Sep 22, 2007 | Mitsubishi VS-55707 TV
Sony STR-DE845 Receiver Logo
529 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
