Question about Sub-Zero 632 / S
My subzero says vaccuum condenser. the freezer is fine, but the refrigerator does not feel like it is at the right temperature, maybe 50 degrees in there. Can I fix this myself?
  • 71 Answers
Nope. you have evaporator freon leak.
Posted on Apr 03, 2010
Subzero 501F icemaker slow in making ice
More thatn likely, being thats an older model, you are low on freom and the temperature isn't cold enough for the icemaker to keep constant production up. You maybe thinking the freezer is fine because stuff is frozen in there but that is why most people don't catch the problem until they lose all their food. The temperature for the icemaker to even come on is 10 degrees F. The sub zero freezer temperature should be around 0. Check your settings and make sure they are turned down but I would get a thermometer and put in the freezer and check to see what it says. If its above 5 degrees F check your condensor coils to make sure they are clean and also see it the condensor fan is running. If dirty, clean the coils and see if the temperature drops, if not call a service company.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 03, 2012 | Frigidaire Refrigerators
The refrigerator on my SubZero 650 is too warm. I set 38 F and the indicator goes directly to 48/50 degrees within a second of me releasing the temp select button. Freezer works fine. I have cleaned the...
I believe it's showing the actual temperature that it's currently inside the refrigerator, not the temperature it's set at. At least that's how my sub zero works. You may need to clean the coils to get it to cool better.
Apr 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
My 650/f sub-zero is not cooling in the refer but the freezer is working fine?
Subzero uses two compressors so the freezer is a separate system. The first thing to do is clean the condenser. You can find instructions on how in the owners manual or at subzero.com. They even have videos. If that doesn't take care of it you could have a bad condenser fan motor a sealed system issue or a temperature sensor issue. Also I have seen if you put something tall enough to push up on the light cover on the top shelf that can stop the evaporator fan at the top of the refrigerator section.
Aug 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Mar 07, 2009 | Sub-Zero 632 / S
My subzero 650 fridge part is too warm , stuck at 53 degrees
Hi There I Have a Digital Video Creator DM-4200 Video Capturewhen i was moving my cds got cracked along all others how can i get software back for a back up..
Feb 04, 2009 | Sub-Zero 650/SRH Stainless Steel
The freezer and refrigerator are not cooling down.
Make sure that the condenser coils under the refrigerator are clean. A dorty condenser will cause the unit noy to cool.
Dec 28, 2008 | Refrigerators
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
The temperature in the freezer ~30 Degrees F
Condenser fan motor replaced. Refrigerator did not work either, so I got mistaken describing the problem.
Jun 09, 2008 | Whirlpool Refrigerators
Sub-Zero 632 / S Logo
177 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
