Question about Making Memories Measuring Tools & Sensors
The plastic shield is broken - Making Memories Measuring Tools & Sensors
  • 25 Answers
Buy a new one from the manufacturer
Posted on Feb 28, 2010
What's the plastic shield blocking the Starter? How to get past it to replace starter?
It`s a heat shield,there should be plastic caps covering the screws to remove that to reach the starter.
Oct 12, 2012 | 1998 Oldsmobile 88
2002 Jeep Liberty Sport with the 2.4L (manual Tran.) Speedometer stopped working, Check engine is on, and now it's stalling between shifting and at low rpm.
Speedometer cable may have broken. You can't tell from the outside of the cable, since it has a plastic shield. You have to disconnect it from the transmission to check it. If you can turn the cable inside the shield easily, it is broken.
Apr 30, 2012 | 2002 Jeep Liberty
When I turn there is a noise. My son looked under the car and there is a plastic part that has broke off. What is the problem?
If the plastic piece is white and the other end attaches to the strut than it is a broken Stabilizer link. Not a big deal and not terrible expensive to replace.
It should look like this
Mar 07, 2011 | 2001 Ford Taurus
Cant find oil filter and key wont turn over
LOOK UNDER THE CAR WHERE BOTTOM OF RADIATOR LOCATED YOU WILL SEE A PLASTIC SPLASH SHIELD WITH TWO LARGE WING NUTS HOLD IT IN PLACE.REMOVE SPLASH SHIELD AND YOU WILL SEE THE OIL FILTER. IF IGNITION KEY WONT TURN IN SWITCH MORE LIKELY KEYLOCK CYLINDER BROKEN. OR KEY WORN OR YOU HAVE WRONG KEY IN THE IGNITION SWITCH.
Feb 21, 2011 | 2002 Oldsmobile Alero
Plastic panel came loose under car, near where front area close to underneath radiator?
just a guard to stop stones an general rubbish sticking to the bottom of the rad hope this helps
May 21, 2009 | 2005 Toyota Corolla
BMW headlight cover
Yes, but I would like to refer you to a link, because there are fragile plastic parts that can easily be broken, and this link has large, concise, clear photos. (A picture is worth a thousand words)
http://www.bmwdiy.info/non-celis-front/index.html
I suggest using mild soapy water to clean the lens shields. Rinse accordingly, and you can even use a blow dryer, to speed the process up. (To wife: Excuse me honey, can I borrow your blow dryer?)
Apr 18, 2009 | 1997 BMW 5 Series
Hood cable is borken can get hood open
if its broken at the handle inside the car use a pair of pliers to pull the silver cable if it is broken outside the car there is a black plastic shield on the underside of the car, remove it and the lack will be visible use a screw driver to release latch
Apr 13, 2009 | Buick Park Avenue Cars & Trucks
Agitator won't move
Sounds like the belt is slipping or broken.
you may be able to see it from the bottom
tilt it back.
Feb 04, 2008 | GE WBSR3140DW Top Load Washer
Dough hook plastic guard is broken
The spare part number for this shield is KW434794
Jan 31, 2008 | Kenwood KM800 Major Classic Stand Mixer
BROKEN SHIELD
Behind the protective shield are two plastic layersright next to each other if the front one is not broken and the quality of the picture is good considering the damage to that specific spot on the screen you should not have to replace it,only remove whats left of the broken shield.Be careful not to scratch that front lens.
Sep 21, 2006 | RCA P61960 61" Rear Projection Television
Measuring Tools & Sensors Logo
177 people viewed this question
Top Making Memories Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Making Memories Measuring Tool and Sensor Expert? Answer questions, earn points and help others
