Question about Casio Music
Keys stup in upright position
While lifting my px 330 ketbord it it slipped & I pulled to my body & 2 keys stuck in up position they still play. how to I get them back down.
  • Casio Master
  • 5,603 Answers
You will likely have to open the case. There may have been some plastic stops that broke off, but keys may just be out of the pivots.
Lots of screws to take out and be VERY careful oof the ribbon cables.
Posted on Jan 31, 2010
I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 | Casio Music
How do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Feb 26, 2015 | Music
How do you adjust casio px 300 when connected to ipad2
Newer Casio models that have "class compliant" USB interfaces such as the PX-330 would work (plug and play) since they now have "class compliant" drivers.
Unfortunately PX-300 is an older model that would need specific drivers and Casio only made drivers for Windows PCs.
May 01, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How do you connect a casio privia px 330 usb to ipad 2
Casio don't supply PX330 drivers for IPAD.
Get a Windows 8.1 tablet or connect PX330 to a desktop PC and use IPAD to Remote control that PC.
Apr 27, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
Pitch drifts px 330
If anyone using a wireless guitar setup is close to it when playing, can do that.
Mar 19, 2013 | Casio Privia Px330 Px-330 88 Key Digital...
Casio px-330bk keys pitch sharp top half of keyboard
The problem you're encountering is actually a feature, called stretch tuning. While real pianos are tuned in this way it's meant to sympathise with their natural 'organics' and might sound wrong on a digital instrument. The solution is to turn stretch tuning off. The manual should be able to tell you how.
Jun 15, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
Casio privia key issue
The only way to analyze this is to open the case. You may find contaminating material has gotten in, or broken part, or key slightly out of position on pivots or pivot plastic broken.
When opening, be VERY careful of the tender ribbon cables. Have a large work surface that you can unfold the top onto. Be careful to use correct screw lengths and thread in each place you removed.
Apr 26, 2010 | Casio Music
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
I have a Casio Privia PX-320. The left side keys
Check that the front of the keys is not hitting the lower plastic case front. If they hit it, then you need to disassemble the case partly and see what has shifted. It is ALSO possible that something has caaaused the aftertouch sensor to move out of position and it is hitting the keys early. ANY of these conditions needs to be addressed before damage is done.
Nov 30, 2009 | Casio Music
Music Logo
Top Casio Music Experts
Ben Armstrong
Piyal Perera
Piyal Perera
Are you a Casio Music Expert? Answer questions, earn points and help others
