Question about Whirlpool WTW5500SQ
My WTW5500SQ washer has been working properly for the last 1.5 year but now water temp selection is reversed!!! Cold is hot and hot is cold!!! Water hoses in correct position since day one... Any Idea?
  • 1 more comment
  • slan_l Feb 03, 2010
    The problem is not the water inlet valves nor the tem sensor... It is the electronic controler that read the temp sensor and control the valves....
  • slan_l Feb 09, 2010
    First, I'd like to mention that I solved my problem by replacing the electronic temp controler (that, by the way, doesn't look like the picture you sent me). This is located inside the machine head and is mecanically connected to the temp selector knob on the front panel. It controls the 2 selenoid valves (hot and cold). I would like to mention that reversing the hoses is not the solution to the problem. Of coarse, by doing this, cold water is flowing when cold water is selected but the problem with this is that it takes an eternity for the tub to fill up!!! Hot valve doesn't have the same capacity (gallon/minutes) as the cold one... So, I had to replace the f.... controler.... For some reason, the controler was still working but with reversed logic! I was not able to find anything wrong with a visual inspection of the controler's PCB.
    I wanted to mention you all this as it might help someone with the same problem asking you for help!
  • slan_l Feb 11, 2010
    No... I found the problem before the esperts...
  • Whirlpool Master
  • 8,220 Answers
Your temp switch must be messed up. To replace it is simple. After flipping up the controls and removing the water temp knob, lift the tab in the rear and twist the switch a quarter turn and it pops right out. If you have questions about accessing the controls let me know,
I have repair photos HERE
Posted on Feb 10, 2010
  • Dan Webster
    Dan Webster Feb 10, 2010
    Glad you could get it fixed.
  • Whirlpool Master
  • 3,740 Answers
An internal failure of the temp control valve would cause the condition that described. Internally there is most likely a contact failure in the water temp control. There is a possibility that there is a wiring problem but it just is pretty far fetched.
This may sound like an odd recomendation but if the machine other wise works normally you will not harm your machine by reversing the hoses on the wall connection.
If you want it back to normal then the water temp control assy. will have to be changed. Item 35 of the following link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5138107&diagram_id=934806#d934806
Close up view:
http://www.appliancepartspros.com/part_details.aspx?part_id=3892216&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5138107%26diagram_id%3d934806
The other componets in the circuit are the water level control and the timer. Based on the symptoms you described this is the most likely failure.
If someone pulled the water valve assy loose and cleaned the inlet screens and disconnected and then reversed the wires on the water valve coils when reconnected it would do exactly the same thing as you stated. There is one common wire to both coils (neutral) and 2 hot leads (line). One for the power to the hot coil and one for power to the cold coil that originate at the temp control valve with power supplied from the timer assy that is shut off when the correct water level is reached and the motor is then powered to agitate.
Myself if everything else worked fine.. I would just reverse the wall hoses and be done with it. It is your machine and your choice to leave it alone and switch wall hoses or.... start ordering the part above that is currently working opposite of what it should.
Posted on Feb 03, 2010
  • 1 more comment
  • Kelly
    Kelly Feb 03, 2010
    Maybe we are not talking about the same model number as you Provided. I don't recall a temp sensor even installed in the model mentioned. Only the timer, temp switch, presure switch and water valves are in the water fill circuit for the model you mentioned. The customer is always right but.... If you know something more can you fill me in please. I did a typo in my original post calling the temp control switch the temp control vavle when it is infact the switch I linked to in my original response. Thanks and lets solve the mystery.
  • Kelly
    Kelly Feb 03, 2010
    Hi, Time for me to be humble. Your machine has a sensor attached to the outlet side of the water inlet valve that controls the temprature mixing. It is actually part of the water inlet vavle itself.
    RH side of water inlet control vale this picture.
    http://www.appliancepartspros.com/part_d...
    You were correct. I still would use it as is and reverse the hoses.
  • Kelly
    Kelly Feb 03, 2010
    Hi, After going back several times you were right. The sensor is part of the water inlet valve itself located RH side of the assy this link.
    Again I would not change the part... it just works backward. Swap the hoses and let it go. There is no danger in continued use with this condition.
    Thanks for making me dig deeper. Even we need that occasionally. (called humble pie)
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This washer is fitted with temperature management which adjusts the water inlets to maintain proper temperature levels. Keeping in view the detergents you should not use very hot water. However, as it is providing water in reverse order then you’ll need to check the water temp sensor and water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 30, 2010
  • Rylee Smith
    Rylee Smith Feb 03, 2010
    If that is the issue then get it replaced.
    Thanks
    Rylee
Cold water valve not working. have checked that water is at outlet of cold water tap. Can you help? thank you
Water Valve Test
When in Diagnostic Mode, the WASH TEMP UP button turns the hot water valve on. The Hot LED is on when the hot valve is on. The WASH TEMP DOWN button turns the cold water valve on. The Cold LED is on when the cold valve is on.
DIAGNOSTIC MODE
Turn the power on at the power point but off at the machine. Press and hold the WASH TEMP DOWN button and then the POWER button until the machine gives 2 short beeps and lights up. Release buttons when the beeps indicate diagnostic mode has been entered.
There maybe up to 3 filters cold water line. There is sometimes 1 at each end of the water hose itself and also in the valve which can be removed with pliers. (see picture)
Undo the 2 screws at the back of the buttons panel
Undo the connection of the valve
If you are good with a multimeter check that there is about 65 ohms resistance across the terminals of the valve. If not, then replace the valve.
Also sometimes the workings inside the valve can jam shut so replace the valve.
Dec 27, 2014 | Fisher and Paykel GWL11 Top Load Washer
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Kenmore 110.42822203 no cold water
Reverse the water hoses and see if you get just cold water. Post back the results.
Nov 06, 2012 | Kenmore Washing Machines
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Hot water comes in cold/cold setting
These machines are designed to have the cold water around 70-75 degrees. If your cold water is colder than that it will automatically mix in hot during the wash cycle to reach that temperature. It all has to do with the optimum temp for proper detergent function.
Eric
Jan 19, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool cloths washer puts hot water out when set on cold or cool setting. And puts out cold water when set to hot. Yes, the water hoses are set to 'H' for hot and 'C' for cold. The machine is less...
inlet valve is definitely malfunctioning. I would just use it the way it is. a new valve plus installation will run you near $150. good luck.
Jul 12, 2009 | Whirlpool WTW5500SQ
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Jan 10, 2008 | Whirlpool GHW9100L Front Load Washer
Whirlpool WTW5500SQ Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
