Question about Brother FAX 930 All-In-One Thermal Printer
Brother fax 930
Hi, overnight my fax has decided it doesn't want to work. The screen says 'date, time, fax' and when I put a letter in it says 'fax: no and start' but when I do that, it keeps beeping at me. When I touch any other button, nothing changes and it still beeps. I tried taking out the phone line and taking the plug out of the wall. That didn't change anything either and it's not asking for anything. Can you help me please?
  • mbungi1 Aug 18, 2008
    I am wondering whenever I put on my fax machine,seems to be okay but when I try to print a report or send out document.It reads "Printer error"with terifying nod sound.
    and thereafter it prints ot the message,saying the electricity failure"
    Can you help me out?
MANUAL PLS BROTHER FAX 930
Posted on Jun 23, 2008
How to change language on Brother FAX-930 . I have on Fax Germany language , buth I need english . Can I do it ?
  1. Turn off the P-touch.
  2. While holding down the Shift key and the "R" keys, press the On/Off key once and then release the "Shift" and the "R" keys.
  3. "English" should be on the display and then press faq_ans_70_return.jpg.
    If "English" did not display, repeat steps 1 thru 2.
  4. "inch" will be on the display, press the "Enter" key.
  5. Set the Date (MM/DD/YY) and Time (hh:mm)
Still having Problem Then follow Us For Brother Printer Support
Feb 19, 2014 | Brother FAX 930 All-In-One Thermal Printer
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Re: Brother FAX-930. LCD display?
I think the LCD screen is going bad. I would try to unplug the machine leave the power off for about five minutes and plug back in and see if that works.
Aug 19, 2009 | Brother FAX 930 All-In-One Thermal Printer
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
http://www.fixya.com/support/p170643-brother_fax_930_all_in_one_thermal/manual-1604
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Copying on the 930
replace your roll, if you havent use for quite some time, chances are this could be overexposed
Aug 30, 2008 | Brother FAX 930 All-In-One Thermal Printer
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother FAX 930 All-In-One Thermal Printer Logo
162 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
