Mother board will not requsise video card gforce4-ti4200
  • tgoodman2005 Feb 01, 2010
    I have fixed it on trying to load drivers for display
    card.
    Thanks for the reply.
  • michaeljsimp May 11, 2010
    What model of motherboard do you have?
  • 600 Answers
You need to install the correct driver first
Posted on Feb 05, 2010
I have an K8T Neo (MS-6702) mobo with an nVidia Gforce4 MX 4000 (NV18) does anyone knows a good upgrade for this motherboard o any video card that can works better? It's and old PC and would like to renew...
The best thing I can suggest is to get an ATI radeon graphics card. You don't say what your Operating system is.
The Sapphire Radeon HD3650 is Vista certified and will fit the mobo you describe (ie AGP x8)
The Radeon is made by the same company that makes the Processor in your Mobo, so compatibility should not be a problem.
Mar 18, 2011 | Computers & Internet
Hi I have SRM Mother board which VGA is suitable for this Please help me Prak
Tell me the exact modle of your srm mother board .is the vga interface agp or pci or pci express? by the way, some vga card need extra power surply.
Oct 28, 2010 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Bought barebones(B69-9005)hade trouble installing win 7 kept saying no signed driver,. called them , they sent me soft ware for driver install. started dowloading then stoped. now monitor just reads no...
If it has onboard video it may be a bad video cable or messed up pin on one af the connectors. If it is a installed video card the cable could still be one problem but also try pulling the video card out unplugging the power supply cable from the mother board for about 20 seconds or so. Then reslot the video card into the mother board and plug the power supply back into the mother board and see if that helps. I have also had to take the small flat battery out of mother board for a second or two to make it reset. If you decide to do the battery thing make sure the power supply is unplugged from mother board. Good luck.=)
Sep 19, 2010 | Computers & Internet
Have gforce4 ti video card NO PICTURE of any kind screen says no signal detected
The GeForce4 Ti has two rear ports. 1 HDMI and 1 VGA. Try plugging into each. Video signal should be sending out of one of the ports. If neither port is sending out signal than you'll need to trick the bios.
Suggest you remove the Gforce4 Ti AGP card from the MB so you can regain video display and change the settings within the bios. Once you have display, enter the bios menu. Do you have your manual? Enter bios menu by pressing the "Delete" key every 2 seconds until the bios menu loads. Open, Integrated Peripherals, see top of page 3-11. Set Primary Graphic's Adapter to: [AGP]. Than go to the top of page 3-10. Change the AGP Aperture Size to as low as possible or to: [Disabled] "preferred".
AGP 8x Support set to: [Enabled]. Save your settings and exit the bios. The system will restart. Press and hold the power on / off button until your system shuts off. Install your GeForce4 Ti AGP video card. Double check your video card! Some NVIDIA cards need external power above what the AGP slot can provides. Some use a power connector like the floppy drive uses. Other look just like a hard disk drive power connector: 4-pin Molex. If none is found don’t worry about it.
Cheers!
Mike
Oct 22, 2009 | MSI K7N2 Delta2 Platinum Motherboard
Nvidia gforce4 4200 (Dell Mobile)
If you want to upgrade a laptop graphics card - you cant!
You are stuck with whatever came with the laptop. btw the nvidia gforce4 4200 is garbage!
May 11, 2009 | Dell Inspiron 8500 ATI 32MB Video Card -...
Please find me better solution
Its really hard to find the proper driver without a specific model number of *********** board. you can get your driver over here.
http://list.driverguide.com/list/company1177/index.html
Mar 24, 2009 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
AGP card not suport to play games
Only solution is to upgrade your video card. ATI Radeon 1650 pro 512 mb card is available in an agp format. This card is probably the best out there for an agp board. All you would need to do is purchase the new card, remove old card, insert new, reboot & use the cd that comes with the new card to install drivers. Hope this helps & please rate my answer fixya. Thanks.
Feb 03, 2009 | Dell /nVidia Ti4200 GeForce4 64MB w/TV Out...
Configuring Nvidia card, etc
DirectX is a microsoft's standard for controling video cards. you can read all of video cards and its affiliations on this link.
http://www.playtool.com/pages/selectvid/select.html
in my opinion, ill choose PCI-express video cards (it should be compatible between the motherboard and the video card) because its not that expensive and it can load a high quality video graphics compare with AGP video cards and by the way AGP cards are expensive rather than PCI-express. hope that helps!
CHARCOIS
Jul 26, 2008 | Intel Motherboard
Ati radeon agp card
Hi Rafael83,
There may be afew things that may be wrong. One, the video card may be bad, two the motherboard may be bad, or three your power supply may not have enough wattage to power your video card. Or it coud be all of the above.
Sincerely,
Agent Xiong
Apr 30, 2008 | Vga GeForce4 Ti4200 64MB DVIout AGP Card...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
