Question about Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum
Motor starts but shuts down Brushes not turning no obstructions on brushes
Was sucking up some powder and after cleaner was emptied and had a rest it appears to be operating again. thank you
Posted on Jan 31, 2010
Brushes won't spin, motor reves down
1. clean the brushes of hair etc and manually turn to see if any obstructions.
2. check the belt and its tension.
It should work.
Mar 03, 2014 | Shark Navigator Bagless Upright Vacuum
H3000 Motor becomes very hot during use
Over heating on a floormate is cuased by obstructions or a clogged up filter. Try running it without the recovery tank. If it doesn't over heat you need to check for obstructions in the nozzle and the tube leading up to the recovery tank. if that is all clear, a new filter should fix it.
If the machine over heats without the recovery tank on it, you might be right. Hoover only sells motor assemblies, not just the brushes. I have never seen them used enough to need new motor brushes simply because of wear. If the brushes are worn down completely, there is probably a short in the motor.
Let me know if this helps.
Dec 31, 2012 | Hoover Floormate H3000 Upright Wet/Dry...
Brush bar not spinning when set to high or low on carpet
1) adjust the belt, see for broken or worn, and replace
2)see for brushroller obstruction, and clean it and repair
3) see if the brushroller without belt run smooth, otherwise repair and fix it.Lubricate.
4)See if the motor run without load( NOT belt+brushroller) very well. in negative case repair motor.
God bless you
Jul 15, 2012 | Vacuums
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
The brushes stopped turning. I cleaned the filter
Can you rotate the brushes manually (grab some of the yellow bristles and rotate the brushes). If they are not jammed, then your air fan drive is clogged or broken. Air must pass through the fan to spin the brushes... so confirm air flow by powering the machine on and feeling for decent air flow. Clear any obstructions that my restrict air flow....
Nov 24, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes not turning
If your brushes are rotated by a black rubber belt, chances are that they belt has stretched out or has been worn and you need to replace that belt, also , check and remove any black rubber residue from the brushes and where the belt loops around. Also check for obstructions thru the hoses restricting air flow.
Aug 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Roomba shuts down after a few minutes
The brushes are clean on the outside, but probably not inside of the little yellow contact on the end. Also the junk that collects on the brushes finds its way into the gear box. Mine kept shutting down w/ the "Please remove and clean Roomba's brushes" message. I finally gave up and took it apart. There was a surprising amount of junk in the gear box. After I got it apart, I cleaned it out and I even used a straight pin and a pair of tweezers to get all of the gunk out. Now it runs like new. I'm no mechanic, but I used to help my daddy fix things around the house. I posted my solution to the problem and it has worked for a couple of other people too.
Dec 15, 2008 | Roomba Robotic Floor Bagless Vacuum
Carbon Brushes wearing out quickly on Kirby Heritage II
4 possible reasons.
1 – one or both bearings are worn so armature (rotating part) wobbles as it is spinning and cause motor brushes to wear fast. Solution – change bearings too.
2 – Whoever replaced brushes – did not use some brush seating sticks to make cmutator smother and contour brushes to the shape of the comutator (not likely). Solution – appropriately install new set of brushes.
3 – Comutator is so warped that seating sticks do not help anymore – solution – new armature or turn the old armature.
4 – The fact that ONLY ONE brush was worn may mean that there is something wrong with the brush or housing. Maybe it could not move freely within the housing? I think this may be most likely cause it it may be a combination of all 4.Is it worth to fix? Hmm depends how much will it be. If this is 100+ - I’d say get newer Kirby for 300 ad enjoy the tech drive (Heritage does not have tech drive so it is much harder to vacuum with than the newer models)
Nov 05, 2008 | Kirby Heritage II Vacuum
Dyson DC05 Cylinder Bagless Canister Cyclonic Vacuum Logo
116 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
