Question about SanDisk Sansa e250 MP3 Player
Recovery mode and USB2.0 mode
My Sansa Rhapsody e250r does not start since about 4 months... I haven't been able to find a solution to this problem, other than sending it back...
I think it's the same problem:
When I plugged it to add music, it asked me to run some Firmware Update and I accepted it
I "updated" my Sansa and it never worked again!
Whenever I turn it on, I keep getting the same message: "Load main image failed" "Switch to Recovery mode" and when I do so, it says "Enter USB2.0 mode"
I have no idea how to do that, given that I can't access the main menu
I have also tried downloading the firmware at http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
and followed the (apparently famous) 7 steps and nothing! Everytime I do the whole "firmware update" thing, it just seems to take no time at all. The player screen shows a bunch of things that the Sansa is suppossed to be doing, but it just doesn't seem to do anything at all.
I repeated that process for about 20 times...
Does anyone have a different solution to this?? Other than sending the bloody device back to where I bought it???
If you do, please let me know!!!
thank you VERY much!
  • 3 more comments
  • Anonymous Mar 02, 2008
    I keep trying to run thehttp://www.sandisk.com/Assets/File/Downl...
    thing, but every time I do I get Error! The downloaded image is not compatible with the connected device.
  • blondegirl Mar 03, 2008
    i have the same problem....the same happens in recovery mode and in regular mode my screen when turned on just keeps flashing the "SanDisk" logo screen and then fades out white before flashing the same thing over again.
  • gcesar9 Apr 01, 2008
    how to fix my sansa e250 its say recovery mode
  • duckdockers Jan 22, 2009
    alguien que me diga como revivier mi sansa e250 por que borre todo el sitema y solo se quedo la pantalla en negro
  • Anonymous Mar 27, 2014
    My Denon S-5 DAB wireless music system keeps crashes and will not respond. It will "com back t life" for no apparent reason, work normally for a while then the process repeats. I have been advised that this could be a firmware update problem
My sansa sandisk e200 was plug to the pc i then remove it and plug another device.when i later power it on all it could display "refresh database".also i fix it to the pc another problem is "recovery mode and usb2.0 msd mods"
Posted on Mar 07, 2008
No installation CD for Sansa e250R
Hi
You can download and install the drivers from this link---
Sansa drivers
Sansa rhapasody player
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Mar 03, 2009 | BoxWave Corporation SanDisk Sansa e250R...
Sansa e250R firmware
hey yeah i had the same problem with my sansa e250r. when mine does that i
1. turn it off
2. put the hold button on
3. hold down the rec. button
4. turn it back on
that will get you into recovery mode connect your data cable once you have hooked it up to your computer open my computer and you should see a 16mb drive there instead of your normal mp3.
once you see that open it up.
now go to http://www.sandisk.com/Retail/Default.aspx?CatID=1449 scroll down and click on download firmware link
once you have downloaded that file unzip it and copy the file that is inside to the 16mb drive that you opened up in my computer.
once you have done all the above,,
1. take the hold button off
2. disconnect the data cable
3. wait for it to reboot.
if the above dosent work you might wanna take it to the dealer.
hopefully this works for you as well as it did me. good luck
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250
hey smart ones(sarcasm) why dont u just buy the Sansa e250v2
its pretty much the same thing, just without rhapsody, thats how me and my friends are, i bought the one with rhapsody features(Sansa e250R) so i can play the songs that i bought and get free music channels for it, where my friend on the other hand has the Sansa e250v2 without rhapsody, u can still use rhapsody but u cant get free music channels for it, or u could also download best buy music manager or rhapsody and set up a free 31-day account for it to stop saying that for a while, plus if u got ur Sansa e250R from Best Buy, they can replace it, or trade u the sansa that u have with the rhapsody-free one(without rhapsody)
Feb 01, 2008 | SanDisk Sansa e250 MP3 Player
Deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Dec 22, 2007 | SanDisk Sansa e250 MP3 Player
Restoring factory Sandisk Sansa e250R settings...
you might want to try right clicking on your mp3 icon while in rhapsody and clicking format device...
Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
Can't download to mp3
Make sure the device is in Rhapsody or MTP mode. Otherwise, the licenses will not transfer. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e250 MP3 Player
New player, says I ran out of space
If you formatted it thru Windows Media Player, or Rhapsody, it didnt really format properly. Make sure the device is in Rhapsody Mode. Settings>Mode or USB Mode>Rhapsody. On your computer go to Disk Management. Right Click on My Computer and select Manage. On the next window select Disk Management, under Storage. On the right side at the top of the window you will see the device listed (i.e. Sansa e250r). Right click on the device and select format. Dont select any other options, just hit Start. Your device is now formatted properly. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e250 MP3 Player
Used memory i never used
With most MP3 players, some of the memory is used for system files and software. Just delete all the things you done use (i.e. pictures, playlists, Rhapsody Channels) and whatever space you have free is what you have to work with.
If you want more memory, I highly suggest a microSD card
Aug 12, 2007 | SanDisk Sansa e250 MP3 Player
Help
Hi tater. Hmmm. The product category you selected is for a Standard E260. But if your player is an E250R (Rhapsody player), here's a set of procedures that might help you. Deleting songs from your E250R can be done in 2 ways: By using Windows Media Player 10 or 11, or by browsing the player through Windows Explorer. Before you delete files, though, it's important to know that your player comes in 2 modes: "Rhapsody" and "PlaysForSure". The reason why is that music files saved in one mode would not be seen in the other mode, and vice versa. Therefore, if you can't find the music files in your player, switch to the other mode. Here's how to do it: Use the "Menu" button to navigate the player as follows: Menu > Settings > Mode > This will give you the option of: "Rhapsody" and "PlaysForSure". Here's how to delete your songs: (1) By Using WIndows Media Player: > Plug your Sansa to your computer and open your Windows Media Player. > If your Windows Media Player is version 10, then click on the "Sync" tab and you should see your player ("E250R") on the right pane along with its folders, named "Data" and "Media" or "Music". Expand the "Media" folder and you'll see the "Music" folder containing your songs. Right-click on a song and select "Remove" to delete them. > If your Windows Media Player is version 11, then either click on the "Sync" or "Library" tab and you'll see your player listed on the left pane. The music files will be displayed on the center window. Right-click on a song and select "Delete" to delete the songs. (2) By browsing the player in Windows Explorer Note: the folders containing the music files on your player are "Hidden" and you would need to set your Windows Explorer to show "Hidden Files and Folders". Open your Explorer, select "Tools" on the top menu, select "Folder Options", select the "View" tab and enable the "Show Hidden Files and Folders" radio button. > Plug your Sansa to your computer and open your Windows Explorer > If your player is in "PlaysForSure" mode, then your player will be recognized as a "Portable Media Device". Double left-click on your Sansa E250R and you'll see 2 sub-folders named "Data" and "Media". Open the "Media" folder and you'll find sub-folders normally named after the Artist. Your songs are located on those Artist folders. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" > If your player is in "Rhapsody" mode, then your player will be recognized as a "Removable Drive" with a drive letter. Double left-click on your Sansa E250R and you'll see the following sub-folders: "Albums", "Music", "Photo", "Pictures", "Playlist", etc. Your songs can be found in the "Music" sub-folder. Delete them by using the keyboard "Delete" key or right-click the file and select "Delete" I hope this procedure helps. A bit lengthy but, hey, it worked for me (lol).
Apr 27, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
105 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
