Compal RM CY25 Laptop. new battery won't charge.
9yr old Compal RM CY25 Laptop did suffer from screen being trod on.
Screen replaced.
New battery.
Old power adapter 19V ok all wires secure and insulated.
Adapter rating 19V 3.68A. = apx 70watts.
Adapter socket on back of laptop OK.
Old battery blinks the LED Orange (Not Red) New battery blinks the LED Green. Been on charge for 8hrs with LED blinking green.
No steady Green LED ever.
Battery down to 11.38V. As tho it has discharged it.
Zero % In battery charger window. XP Pro.
Laptop will boot on power adapter supply, with or without old or new battery.
I've tried several adapters @ 19V and one with 6.3A = 115Watt
Thank you in advance for any help.
Bob
  • 36 Answers
Unfortunately, the charger socket in the motherboard does not drive electricity to the battery to get re-charge it. It is a typically motherboard problem(Do not confused with a power jack problem). I can not be repaired it.
Two options work always hook with power adapter or get ride of her.
Posted on Apr 10, 2010
New unlocked cell phone won't turn on
Hey, same problem. Push and hold the hangup button. It will prompt to insert sim , but I only have one. The phone works. The website and the manual are useless. Just gotta play with it, I guess.
Mar 06, 2013 | Cell Phones
Sceen shows that battery is not charging.
Check the connection for the battery. Make sure it's seated properly. Then reset the NVRAM.
Nov 13, 2012 | Apple Computers & Internet
Compaq presario cq62, plugged in but won't charge battery
The rechargeable battery needs to be replaced, the old one is just about exhausted. Go to www.ebay.com Type: make and model of laptop, refine search to battery, and I recommend sticking with new genuine.
May 04, 2012 | Compaq Presario CQ62-112TU
Solo 9100 battery
Well, 8 years is an excellent life for any laptop battery. Being that old it will either be a nicad or nimh battery, both of which suffer from battery memory. There is very little you can do. Sometimes, charging the battery as much as possible, REMOVE IT FROM THE LAPTOP, put it into a plastic bag, seal it against moisture, and then put it into a freezer for 12 hours. Replace it into the laptop, charge it again, repeat twice more. If the battery has a bit of life in it you may be able to reclain SOME of it's capacity back. This is a last ditch effort, and should be carried out as a last option. That leaves either buying a new battery, this eBay link will take you to one
http://cgi.ebay.co.uk/NEW-Laptop-Battery-for-Gateway-Solo-2300-2500-9100-9150_W0QQitemZ230370600615QQcmdZViewItemQQptZLaptop_Batteries?hash=item35a32866a7
It's probably time to replace the whole laptop though.
Hope this helps
Jan 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
My new acer laptop only works if pluggd in
u try one thing just shutdown laptop remove battery and charger from laptop then after push power button for 1 minute after that install battery and charger. but not start laptop and check that charging led of laptop is running if it's runnig then put in same condition for 3 to 4 hours after that start laptop using battery only after proper booting when os load attech the charger and check charging status.
Dec 27, 2009 | Acer Aspire One PC Notebook
Compal CY25 Maual
You will need to get in touch with Compal as there seems to be a problem with their website; http://www.compal.com
May 07, 2008 | Compaq Presario 700 470024-192 Notebook
Compal cy25 laptop
You can find drivers and manual @www.bizcom-us.com/support/TechSupportDriversDownloadPage.htm#cy25
Mar 24, 2008 | Computers & Internet
Rm cy25 service manual
Compal manufactured this computer and it was sold under many different manufacturers names.
To remove optical drive: Extract the two screws in the base that obviously attach to the drive. Remove cover from memory, roughly in centre of base, and you will see a screw that secures the drive. Remove the screw and the drive will slide out. Remove the bracket on rear of drive, attach to new drive and reverse above procedure. Memory is located under the said cover and also under the keyboard. Not too difficult to remove keyboard. Remove switch panel after removing screws in back of hinges. You will see several screws on rear of keyboard. Remove these (very small) and keyboard will swing upwards and out. Beware ribbon cable connector underneath as removing keyboard. You will then see second memory location. Max mem 1G
Jan 14, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
