Question about SanDisk Sansa e250 MP3 Player
Sansa E250 wont properly turn on
My e250 was working fine for months and even earlier today, i came back from my friends tried to turn it on for the walk home but now it just has the loading image of "sandisk" and keeps restarting itself, i tried connecting it to my computer and it does the same thing
  • 9 more comments
  • Negi89 Feb 20, 2008
    yea mine jus recently started doing that as well after 7 months...but like 5 hours b4, it gave me a screen of difrent color stripes then started working properly for an hour then after a 4 hour study group that it was off, i started it up and then it jus keeps looping the SanDisk and Rhapsody intros....please find a solution fast.
    Steps i've taken include using lock to shut it down since jus holding the power button in wont shut it off, and i tried hooking it up to my computer which didnt work and then have let the battery run down and tried to charge which it still gets stuck in the loop.
  • ravi31 Feb 23, 2008
    I too had the same problem, Somebody post a solution.. please
  • Anonymous Feb 27, 2008
    My Sansa has worked well until today. When I turned on Music, it said: "Not enough space for music DB. Please free 6MB."
    I clicked "Album," it said: "Empty."
    Anyone can help? Please.
  • Anonymous Mar 10, 2008
    same thing
  • manu_chloe Mar 21, 2008
    i have the same problem with my mp3 starting up and i tried the link in the solution but it jus keeps saying file not found.
    what should i do now?
  • Corb monty Mar 22, 2008
    When i turn my e250 on it says sandisk but wont get to the main screen it just keeps starting over w/ sandisk then it goes white then it says sndisk again, over and over i plugged it into my computer but it does the same thing
  • Anonymous Aug 21, 2008
    HELLPPP!!!!
  • jonah892a Aug 21, 2008
    When I turn my e250 on it says sandisk but wont get to the main screen, it just keeps starting over w/ sandisk then it goes white then it says sndisk again, over and over. I plugged it into my computer but it does the same thing. The computer also doesn't recognize that it's plugged in - doesn't show up on any USB port.
  • skeeterkins Apr 06, 2009
    mine lets me turn it on but when it gets past the sandisk part then says Image file load failed please put in recovery mode
  • Anonymous Apr 25, 2009
    my sansa would not open up, but i tried ravi's method for getting it into recovery mode and it worked!..But what should i do now? Do I have to reset it or should i just leave it?
  • adujink May 11, 2010
    Solution link . . .
    http://www.Sansae250MP3Player.com
Hey .. I have a solution for this.. download pp5022.mi4 and sansa.fmt from the link
http://rs109.rapidshare.com/files/29178834/Sandisk_Sansa_R_Series_Recovery.exe
unzip these files and connect your sansa to the PC in recovery mode. You will find a 16mb drive opened and add these unzipped files into that drive and disconnect sansa from the PC. It will refresh and recover to the normal state.
By the way, to go to recovery mode press and hold the power button until the player turns off. Then switch it to locked state by switching the button at the top. Then press and hold the record button on the left and press the power button. Do all this after connecting the device to your PC. Good Luck.
Posted on Feb 26, 2008
  • ravi31 Apr 03, 2008
    Well... I tried triggerhouse' s solution even before posting mine. I swear.. it doesn't fix the above problem.
One thing you can do to Easily re-set the E250 (for sure) is to take a small philips (star) scewdriver and remove the back plate or cover by takiing out the 4 mini screws.. When you get the back off, you will see the battery. Just pull it out by the bottom and disconnect the power connection to the battery. Now count to 10 and reconnect the wire to the battery.Put the battery back in and screw the back plate on.Turn it on and "presto". Do not do this while connected to the Computer. No- you will not get a shock doing this! Ha!
Posted on Mar 22, 2008
    Problem Solver:
Does this mean that you lose all of the files you have on the sansa?????
Posted on Mar 16, 2008
No operator's manual for e250
Here is the link - a Sansa e250 has a Sansa e200 series manual:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player starting problem
Do a Firmware upgrade first - http://www.sandisk.com/sansa/#/support-0/
Enter Sansa e200 series
If this does not work, try the other methods I suggest in my Sansa player "Tips and Tricks" - click on My Profile if you do not see the article in the solutions section (no offense to Fixya, but your website is not yet user-friendly - needs some work).
Jun 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 computer problems
Try using Windows Media Player instead, and see if you get the same result. If it loads in Windows Media Player, then the problem is with WinAmp and not your Mp3 player. When you say it loads half-way, do you mean it loads half the songs and then shuts off? Is the Sansa running on low battery? WinAmp has some kind of update released in the past week - did you download the update, and then experience the problem? It's probably not this, because other users have had the same problem that you are reporting since at least Christmas 2007.
The following is an advice from another Sansa user, so I haven't been able to verify it myself:
"I have to have WinAmp open and a song playing then connect my player and then it will work fine. If I just connect my player then start WinAmp it crashes"
If all of the above fails, reformat your player and start over from scratch. Let me know how everything works out - this is an issue that not even the Sansa website seems to have an answer for.
-Tha Mp3 Doctor
SD card wont let me add anything
I don't think that the sansa e250 supports sdhc cards these cards 4gb and up are only compatible with newer electronics
Jan 28, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 MP3 Player Problem
convert the songs to mp3 or just delet all of your song and try again it worked for me
Jan 16, 2008 | SanDisk Sansa e250 MP3 Player
I have a pretty big problem with my sansa e250
Linux = problems - go to Linux forum after grabbing as much software info as you can from Sandisk's website.
Aug 18, 2007 | SanDisk Sansa e250 MP3 Player
It wont read any file
If you just got this sansa, call sansa and send it back to them. you still have a warranty. they may give you some problem if you don't have the reciept bu explain that it is a gift. From what you say, you did what you should have. you can always send it to my company so we cna see what the problem is. Thanks, Connie
Jun 20, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e250 wont turn on
try undoing the back of it and take the battery out put it back in then try turning it on try it a couple of times this was only a temp fix for me
Oct 14, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
381 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
