Question about Air Tools & Compressors
Oil is shooting out fill tube - Air Tools & Compressors
  • compman66
    compman66 May 11, 2010
    Is it over filled with oil?
  • 409 Answers
Sounds like you have a broken ring or cracked piston. Will take a teardown to prove this out.
Posted on Mar 13, 2010
Dual flush toilet fills slowly. The fill valve is pushing water cistern seems ok. The fill hose shoots water down overflow tube this is the design. If hose placed tank it fills no problem.
check /replace the small rubber washer at the end of the fill tube as they tend to grow with age and reduce the flow of water past the inlet
Oct 11, 2016 | Home
Filler tube in back leaks or shoots off fitting going to ice maker
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 07, 2011 | GE (ESS25KSTSS) Side by Side Refrigerator
My 2004 dodge ram 1500 4x4 with a hemi 5.7 will not accept fuel.As soon as i start to fill it backs up the filler and stops the pump.the only way i can fill the tank is to hold the fuel nozzel out of the...
my 2004 dodge ram 1500 2x2with a hemi 5.7 will not accept fuel.As soon as i start to fill it backs up the filler and stops the pump.the only way i can fill the tank is to hold the fuel nozzel out of the hole ans slowly shoot the fuel into the filler tube.This is not only unsafe for my wife and kids but very time consuming.replaced fuel fill tube already and had breather tube blownout and scoped by a mechanic.He now tells me i need a new $500 gas tank.Is this something i can have the dealership fix for free?
Feb 13, 2011 | 2004 Dodge Ram 1500
Oil pump ,,,where is the oil pump located on a 1997 dodge caravan
Hello
Welcome!
Oil pump is located on the oil pan.
Parts needed,,,oil,,,, oil filter,,,, oil pan gasket,,, oil pump,,,, oil pump pickup tube..
time to do this,, about 3 hours
Instructions,
Raise van place on 2 jack stands
drain oil remove oil filter fill new filter install.
remove bolts from oil pan,
remove oil pan..
remove 2 bolts that hold oil pump and tube.
install new pump and tube tork bolts to 45 fp
replace oil pan gasket and install oil pan
tork pan bolts to 35" pounds
install drain plug
fill with oil
start and check for leaks
let me know if i can help more
Jul 17, 2010 | 1997 Dodge Caravan
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
Air compressor shoots oil out of fill tube / only 70psi.
i would say air is getting through piston rings and needs rebuild
Aug 21, 2009 | Air Tools & Compressors
Water shoots out when i flush
either your fill tube came out of the tube in the center that the flapper is connected to or the fill valve wore out.Usually this happens when the little plastic or rubber hose coming off the fill valve comes out of the over flow if you secure it to the center tube so the water goes down it you'll have a dry floor and better working toilet
Aug 11, 2009 | Home
Oil blowing out of trans breather tube
hi 81 yamaha i am concerned about the fuel smell coming out with the oil. could be the carbs flooding filling your crankcase with fuel? if not it sounds like you have blow by which would cause your crank case to be slightly pressured. this is caused by worn piston rings. do not plug your crank vent. if you leave your vent open install small filter to stop dirt from entering jim
Mar 21, 2009 | 1981 Yamaha XJ 650
Air Tools & Compressors Logo
54 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
