Question about Canon PowerShot S3 IS Digital Camera
The lens will not come out fully, it clicks some and then beeps. it happened at random, it was not dropped or mistreated. The lens will come out some, but it generally needs to be pushed back in. The camera itself won't even let me view the pictures on it, or anything. It just reads ''Lens error''.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 23, 2012
dbarchitect
  • 150 Answers
SOURCE: Lens stuck out
The lens probably has some dirt or grime stuck in the lens motor. If you can gently twist the lens back and forth, maybe with some air.
I have answered this in another post. Here is the link.
If this helps you, please return and choose FixYa! ThankYa!
Posted on Dec 04, 2007
SOURCE: My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Posted on Jul 01, 2008
SOURCE: I have a canon powershot
I have a canon powershot a470nd i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
Posted on Dec 18, 2008
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
SOURCE: Lens won't close.
I just found the culprit causing my camera to do the same. Under the battery door there is a post that hits a switch. That switch needs to be activated when the door is closed in order for it to work. Safety feature to allow someone not to put in a SD card while camera is on.
Posted on Aug 14, 2009
Nikon lens jammed
This happens due to over extension of lens by motor or encoder failure. Please try few things.
1. Remove battery wait for 20mts, replace with fully charged battery, lens may return to original position.
2. Struck up click button also give similar problem.
Aug 30, 2014 | Nikon Coolpix L320 Black Digital Camera...
When I turn on my Nikon Coolpix S9100 the lens opens, then closes, then opens and closes again and comes up with a lens error. The camera has not been dropped or mistreated. Is there anything I can do...
Thanks a ton Ty Price for the very detailed write-up. Fix#3 did the trick for me for now, my Nikon Coolpix S9100 has started again but I can almost feel the friction in the lens. Surely something is stuck inside the lens barrel. What is the best way to 'clean' it? Any suggestions on that will be much appreciated. Thanks !
May 30, 2011 | Cameras
Lens won't open
low battery, battery not making good contact, else it is repair
Mar 16, 2009 | Olympus FE-230 Digital Camera
E18-lens stuck out-not fully out-won't budgein or out any further
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. As you've dropped it, you might need to start with Fix #7:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 06, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Lens stuck, green Power light flashes, nothing happens.
get a butter knife or any thin object like that and use it to push out the lens and turning it on at the same time  you will hear a clicking noise which is normal  once completely out, use your hand with a gentle but firm presure move it form left to right
and then hopefully it should work after that
x
Dec 08, 2008 | Samsung Digimax S500 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Samsung s700 camera lens won't retract
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 15, 2008 | Samsung Digimax S700 Digital Camera
Canon G9 dropped
I was told it happens when the battery is low
Aug 20, 2008 | Canon PowerShot G9 Digital Camera
I have a canon powershot tx1 and i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
Jul 24, 2008 | Canon Cameras
Canon PowerShot S3 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
