Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Briggs and Stratton pressure washer will not spray water. The engine is fine but water does not flow.
  • 66 Answers
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Posted on Jan 30, 2010
Engine runs fine. But it quits when I pull the trigger on the wand to start washing
Does this behavior change if the engine is warm and on minimum choke? Do you get any water spray before the engine quits? Carburetor could be dirty or float stuck. Try putting dose of carburetor cleaner through engine and cycle choke lever and engine speed lever back and forth while engine is running after it has warmed up without running water spray. See owners manual.
Apr 03, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Water doesnt flow through my pressure washer when the enging is running
But, does it flow through when the engine is off?
If no water goes through either way, it can be as simple fix as cleaning the noozle. Remove the noozle, or the gun, and finally the out flow hose. If water flows through, start adding components from there. Also make sure that your noozle is turned on with full flow.
May 04, 2014 | Briggs & Stratton Pressure Washer...
My pressure washer will not mix with detergent
First you need to see if you have to utilize a soap nozzle normally black in color and with a large orifice that should create low pressure and or a selective change over nozzle with a spray pattern of 65 degrees.If so then you may have a clogged port where the chemical line connects to pump inside there is a check valve with a ball bearing that may be stuck from previous use without rinsing,free the ball by letting water flow with no trigger gun connected just water coming out of hose engine off and insert a nail or pin long enough to push the ball that is in the barb carefully til you hear ******* good luck.
Sep 15, 2011 | Briggs & Stratton Briggs Stratton 1800...
I have a Briggs & Stratton Pressure Washer it was just working Fine THEN the water stopped coming out of the wand? Any Suggestion
Remove the tip and pull the wand trigger without the tip in. If water comes out then your tip is clogged. Clean the tip and reinstall. Or try a different tip.
Its also possible that there is a kink in the supply hose to the unit.
Try these first, it should solve the problem about 90% of the time
Jul 02, 2011 | Briggs & Stratton Pressure Washer...
Craftsman pressure washer constantly fluctuates and then stops
sounds like fuel problem. Either water\trash at bottom of tank, or most likely, carb needs to be disassembled and bowl and jets sprayed out w\carb cleaner.my money is on the latter.
Jan 29, 2010 | Briggs & Stratton Pressure Washer...
I have a briggs & stratton pressure washer that every time I engage the spray hose my pressure washer stops. Why???? I have left it running for a couple mins. before engaging, doesn't seem to help
PROBABLY the valve that admits the water to the pump is sticking. USUALLY bad O-Rings. If the valve sticks closed, the pressure won't build up. If it sticks open, the washer will stall. Most other problems are engine problems due to bad gas, carbureator, etc.
Oct 09, 2009 | Briggs & Stratton Garden
Can get no water flowing to the spray nozzle
Most likly the sliding nozzle valve is not fully down or up. I have found after the nozzle lay about for some time they get stuck from water scale. It took two persons pulling and pushing on the valve to get my to operate again. It worked for me.
Jun 11, 2009 | Briggs & Stratton Adjustable Spray Nozzle...
Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Mar 17, 2009 | Briggs & Stratton Pressure Washer...
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
1,482 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
