Rank: Guru
Rating: 86%, 169 votes
I would say the power supply is not working. May be something as simple as a fuse. To check the fuses, a person must always to first, unplug the set from the wall. Then take the screws/1/4" nuts from the bottom back panel of the set. You should be able to take a flashlight and observe any bad fuses, or better yet, if you have a continunity checker ( vom/dvm ) use that to check each fuse. There are usally more than one in a big screen. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
