Question about Tricity Bendix TM310W Electric Dryer
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
Hello, I wonder if you can help me my problem is that i am trying to replace a belt on a Tricity Bendix TM 320 W Tumble Dryer. Thank You, Eugene O' Halloran
  • Anonymous Mar 20, 2014
    2006 tricity bendix TM 320 W tumble dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Posted on Feb 09, 2010
Tricity bendix tm 550 motor spring adjustment
If there is no provision for adjustment, the spring may have lost its tension and will have to be replaced.
Nov 18, 2016 | Tricity Bendix Dryers
Tricity Bendix tumble dryer TM 560 will not Heating but drum is rotating.
Hi, it could be the heating element needs to be replaced, best get it checked.
Apr 05, 2016 | Tricity Bendix Dryers
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
Tumble dryer running but not heating up its a tricity bendix tm 545
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Nov 09, 2009 | Tricity Bendix TM310W Electric Dryer
Dryer shorts out some of the electrics when its switched on!
The breaker in your breaker box is either weak and need to be replaced or the amps is too low. But from what you stated, you have had this dryer for awhile, so I'm assuming that its just a bad breaker. If the dryer still runs and doesn't have any issues when it dosn't pop the breaker, then this is what it is. Have an electrician come out and replace the breaker if you are not familiar with doing this.
Apr 10, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix TM310W Electric Dryer Logo
2,637 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
