Question about Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 LCD display doesn't work correctly
Hi, I have a Grundig Satellit 800 radio and the LCD display is unintelligible. When I turn the tuning knob the display changes but is still unintelligible.
  • 494 Answers
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Posted on Feb 10, 2010
Satt 800 turns itself off and wont reset. I NEED IT REPAIRED! Am in Alabama
R.L. Drake in Ohio can and does repair the Grundig 800 Millennium receiver.
Contact John Kriner there, and advise him that I sent you.
See info below.
Joe Rotello
Knoxville, TN
John Kriner - Lead Tech. Knows Grundig 800 inside and out
jkriner@rldrake.com
USA
R.L. Drake
230 Industrial Drive
Franklin, Ohio 45005-4496
Phone Numbers:
Office & sales phone: 937-746-4556
Technical support and repair parts phone: 937-746-6990
Aug 21, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Can u give me the pincode of that area
Feb 04, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
I just got grunding 800 radio,no reception either am,fm ,sw please help me.
This is valid for the Satellit 750 by Eton (current owner of Grundig)
When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range.
If it is used in North Ameraica, you are told not to go through procedure but do it any way.
SYSTEM Code setting
Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display
1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages.
2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America)
The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
Aug 11, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Nov 20, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Looking for manual
HI,
DOWNLOAD PDF FILE FOR 800 SATELITT
GO TO GOOGLE ENTER SAT 800 GRUNDIG PDF
YOU WILL GET A MANUAL FREE OF CHARGE....
Nov 13, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Repairing Grundig Radio receiver Satellit 3400
GRUNDIG SATELLIT ST 1400 SL
Diodo Zener ST601 Volt ?? (SU ALIMENTAZIONE)
HELP Simon
Feb 27, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 500 loses reception
Hi
I had such a pb.
IC 103 CX7961 stopt to oscillate after ~30s ...
so the plls ref was out
I changed it without results
In fact the plastic trimmer C138 (4-20pf) was bad???( insulation?)
Since changing (10 years ago) : no problem
Good luck
Dec 13, 2007 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 AM/FM/SW Radio Logo
448 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
