Question about Whirlpool Duet GHW9150P Front Load Washer
WAS FLASHING F-01 REPAIRMAN SAID TO REPLACE THE CCU BOARD ,ORDERED PART AND STILL DOES SAME THING.
  • 65 Answers
Usully an F-01 error has nothing to do with the control but the drain pump itself. First locate the access panel in the front of the washer directly under the door. There should be 3-4 screws down in the bottom that when removed the panel will slide down and fall off. Behind the panel is a drain pump assembly, use this link as a reference http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0501061-00006.png The part #14 unscrews counter clockwise out of the pump housing. Make sure this cup is cleaned of all debris and reinsert it into housing. If this does not repair the error code, you are going to have to replace the pump motor itself (part #10 in the picture). This should get you back up and running. Hope this helps.
Posted on Jan 30, 2010
What does error code f-01 mean
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred. Generally in order to correct this failure the CCU board will need to be replaced.
Before you cal the repairman, try unplugging the washer for 3 minutes and then power up again and see if the error clears.
Good luck.
May 11, 2015 | Whirlpool WFC7500VW Washer
Code error F 01
EEPROM ERROR
A communication error between the Central Control Unit (CCU)
and the EEPROM onboard the CCU occurred.
PUMP DRIVE ERROR
The pump driver fails to activate.
MAIN RELAYS ERROR
One of the main relays is not working properly.
A power glitch may cause this error.
Unplug washer or disconnect power for two minutes.
Verify CCU operation by running a Diagnostic Test or any cycle.
Replace CCU board.
The relay might be soldered or always open.
Replace CCU board.
May 23, 2012 | Whirlpool Washing Machines
F 01 code door don't lock
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Dec 29, 2010 | Kenmore HE2 Plus Front Load Washer
Flashes F-01
Sorry to read about your problem, I hope this helps you out.
F/01 is an EEPROM error on the CCU. A power glitch may cause this error; unplug washer or disconnect power for two minutes. then you'll need a new CCU-- not a rare event on this washer.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a F-01 fault code on my Kenmore HE2plus front load washer. model # 11047512601. Sears talked me thru the software resets and still had the F-01 error. do I need to replace the Main Control Unit?
Thank you !!
Jun 28, 2010 | Kenmore HE2 Plus Front Load Washer
The estimated time remaining screen is flashing F-01. What should I do and what does it mean?
Good Luck!!
Jun 20, 2010 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2010 | Whirlpool WFW8300SW
Have a kenmore he plus 2 front loader it flashes f-01 i have unplugged it for a hr. and then plugged it back in about a half hr later and it still flashes
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Error: F 01 and it wont start! I unplugged it for 2 minutes but it still reads 01. I drained the water and it still reads F 01
May 04, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2t Error Code F 01 flashes
sF01 - There may be an internal problem with the control, attempt a Hard Reset.
Mar 16, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
268 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
