Maytag A511 has worked faithfully for 26 years.
My Maytag A511 washer has worked faithfully for 26 years. It's never had anything done to it, not even a belt replacement. Now it is making a grating err-err...err-err...err-err noise during the wash and rinse cycles (whenever the agitator is active). What is likely to be the problem?
  • Washing Mach... Master
  • 11,800 Answers
Either the engine or the drum bearing are worn out and the rotor/drum is touching the stator/tub. It's normal wear and since replacement parts are no longer fabricated i think it's time to buy a new one.
Posted on Jan 30, 2010
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Code f24 comes up on mhwz2600tw00 and I changed user interface , mico computer machine control and door latch. Machine will come on with door open but when I shut door machine will not come on.
I removed back from washer and found wire broke .I also found packet with all codes and wire diagram. Repaired wire and washer works fine. I have had this washer for 2 years and the back has never been removed until this time. I think when washer was assembled wire was pinched and during all the washing in 2 years vibration finally finished breaking wire. All tech. from Maytag can't or want tell you anything about their machines. All they want to do is swap out parts and charge a arm and leg for thei service. You are wasting your time to even call Maytag for tech. support. They don't know anything about codes or anything else. If all applinces go out, refg.,dryer.washer.mico.,range, it want be replaced with another maytag.
Jan 28, 2010 | Maytag Washing Machines
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
Model A511 washer Agitator is not moving as vigorously as it used to. Removed front and found excessive oil residue in the bottom. Repair or buy ?
excessive oil . is usualy found under the machine / if inside / on side's of shell this could be water seal leakage . the 511 is a very good machine but its also very old . . agit problem is usualy in the belts and motor roller base . /try cleaning the pulleys and replace belt set / 2011124 and 2011125 / put a roller base set w springs . this will perk it up ,,use info on belt package for belt adjustment. they run loose. ( do not over tighten .)
Dec 18, 2009 | Washing Machines
Hi, i removed the front panel on my maytag a511...now i cant get it back on. I can't see how the top clips work.
the top clips are hanging type.. start with the top clips below there respective recesses in the units top, then tilt the bottom of the front out till it gets to about a 35-45degree angle and the clips should hook onto the top panel and then allow you to swing it shut and replace the 2 screws at the bottom..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool LSQ8000 Top Load Washer
Maytag A511 washer tub vibration
The tub should not become unbalanced over time. There suspension springs may wear unevenly, however. Replace all of the suspension springs and it should be fine.
Jul 31, 2009 | Whirlpool LSQ8000 Top Load Washer
Old machine; model A511. wash cycle won't
Should be worth fixing. Belt kits for Maytag A511 washers are still available on line (about $30).
Jul 08, 2009 | Washing Machines
How do i open the top on an old maytag A511 washer?
Hi, Remove the two screws holding the front panel to the cabinet. The screws are in the slanted part if the front panel.
After the [anel is removed, locate the two 3/8" screws in the upper corners holding the top to the cabinet. The top will raise up. I hope this helps.
Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Whirlpool LSQ8000 Top Load Washer
I have a maytag model
the machine is several years old and may have multiple problems one could be the timer since it is not cutting off, and either a problem with the water pump or something blocking it
probally time for a new washer
May 05, 2008 | Washing Machines
Stains on clothes
yeah if the seal has gone even slightly then it will send grease out 1 way to check if the bearings are on there way out is pull the washer out take the back panel off and look in to see if there are any green spots on the back off the washer if there is then there on there way out another way is to place your palm on the front of washer place your fingers into the drum and pull your fingers up if there is movement then there going m8
Feb 09, 2008 | Washing Machines
Washing Machines Logo
324 people viewed this question
Top Washing Machines Experts
