Question about Panasonic KX-FL541 Plain Paper Laser Fax
My fax machine have long "bee bee" voice when i connect the line
Hi? Actually i have changed the date of my fax machine. Once fixed. My fax machine have long "bee bee" voice when i connect the line. I do changing the advance setting too. But no use expert can help please?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Panasonic Master
  • 1,362 Answers
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
We have just one phone line that handels both incoming calls and faxes. Is there a setup proceder for faxes that are not on a dedicated line. When people call in they get a fax sound and it does not go to...
Hi there!
Mfc-970mc has a built-in message center that you can use. Once you activate this setting the person who's calling you willnot hear the fax tone again. On this setting you will receive faxes and voice calls on the same phone line/ phone number.
Please open the manual and check pages 79-95 to set up the built-in message center of this fax machine.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_870MC_MFC_970MC_EN_90.PDF
Please rate and hope this helps.
Mar 29, 2011 | Brother MFC-970MC Plain Paper Thermal Fax
Machine tries to fax while on phone
Hi ...
There are situations when fax interrupts the telephone conversation. The possible cause of this issue is Remote RX feature on MP 780. There are 3 possible solutions to these problems which are listed below:
I) Change Remote RX ID on MP780
  1. Confirm the <Fax> button light is lit. If the light is not lit, press the <Fax> button.
  2. Press <Menu> button. [RECEIVE MODE] will appear on the display.
  3. Press < (left arrow) or > (right arrow) to select [RX SETTINGS].
  4. Press <OK>. [ECM RX] will appear.
  5. Press the < (left arrow) or > (right arrow) to select [REMOTE RX].
  6. Press <OK> twice. The current Remote RX ID number will appear.
  7. Press < or > to select the desired Remote RX ID number. The options are from 00 to 99.
  8. Alternatively, you can press the numeric keypad to select the number.
  9. For example, to select [38], press <3> and then press <8>.
  10. Press <OK>.
  11. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
II) Turn off Remote RX on MP780
  6. Press <OK>. The current Remote RX option [ON] will appear.
  7. Press < or > to select [OFF].
  8. Press <OK>.
  9. Press <Stop/Reset> to return to standby mode (date and receive mode will appear).
III) Choosing a receive mode MP780
If you want to receive only faxes automatically with your machine, or you have a dedicated telephone line for fax use only:
  • Select [FAX ONLY MODE].
    When you receive a fax call: The machine will receive the fax automatically.
    When you receive a voice call: You will not be able to answer the call.
If you receive mainly voice calls and sometimes faxes, or you want to receive faxes manually:
  • Select [MANUAL MODE].
    When you receive a fax call: The telephone will ring. Pick up the handset and if you hear a beep, press <Black> or <Color> on the machine to receive the fax.
    When you receive a voice call: The telephone will ring. Pick up the handset to answer the call.
    For remote receiving: If you are far from your machine, dial 25 (the remote receiving ID) on your telephone to receive faxes. (Telephone being used, such as a base station for a cordless phone, must be connected through the MP780 for the remote receiving function to work.)
If you want to receive voice messages on your answering machine and receive faxes automatically:
  • Select [ANS.MACHINE MODE].
    When you receive a fax call: First the answering machine connected to your MP780 will respond to an incoming call, and then the MP780 will receive faxes automatically.
    When you receive a voice call: The answering machine connected to your MP780 will respond to an incoming call.
If you want to receive faxes automatically as well as voice calls:
  • Select [FAX/TEL AUTO SW].
    When you receive a voice call: The machine will ring. Pick up the handset to answer the call.
If you have subscribed to a Distinctive Ring Pattern Detection (DRPD) Service with your telephone company (US only):
  • Select [DRPD].
    When you receive a fax call: The machine will ring according to the ring pattern you have chosen and receive the fax automatically.
    When you receive a voice call: The machine will ring according to the ring pattern you have chosen. Pick up the handset to answer the call.
Dont' forget to vote if this helps .... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I use the fax without going thru my computer just as a fax
Issue: How do I connect a telephone, answering machine or computer modem to my machine?
Solution: Connecting the telephone line and external devices to the MX310
Preparing the Machine for Faxing title-bar.gif Typical examples of connecting the machine are described below. The machine cannot send/receive faxes if the connection is incorrect. Connect the machine correctly.
i_important.gif Important
If the Power Disconnects Unexpectedly
If there is a power failure or if you accidentally disconnect the power cord, the date/time settings as well as all documents stored in memory will be lost. User data and speed dialing settings are retained. If the power disconnects, the following will apply:
bullet_s.gif You will not be able to send or receive faxes or make copies.
bullet_s.gif If a telephone is connected to the machine, you can receive voice calls.
bullet_s.gif Whether you are able to make voice calls depends on the type of your telephone.
sikaku.gif Methods of Connecting External Devices bullet.gif Connecting to an Analog Line t_01522.jpg
(A) Telephone line (analog)
(A) Telephone or Answering machine
Do not connect the machine and external devices in parallel to the same telephone line using a splitter (A) . The machine may not operate properly.
bullet.gif Connecting a Telephone or Answering Machine via a Computer t_01724.jpg
(A) Computer
(B) Telephone or Answering machine
sikaku.gif Methods of Connecting the Various Lines The following are some basic connection schemes that apply when you are connecting to a non-analog telephone line. These are examples and are not guaranteed to suit every connecting conditions. For details, refer to the instruction manual supplied with the network device (control devices such as an xDSL modem, terminal adapter, or dial-up router) you are connecting to this machine.
(A) Digital Subscriber Line
(B) Splitter
(C) xDSL modem (splitter may be built-in to the modem)
(D) Computer
bullet.gif Connecting to an ISDN Line For details on ISDN connection and settings, see the manuals supplied with your terminal adapter or dial-up router.
Please be informed that you can access Canon's online support site for your printer by clicking here. You can find many solutions to your problems by searching their database once you have navigated to the support page for your model.
I hope this information allows you to resolve this issue. If not, reply back with a comment to this thread.
If so, please take just a moment to rate this post. Thanks!
Apr 03, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon pixma mp530 all-in-one printer set up
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Solution: Changing the TX report MP530
Change the TX Report 1. Press the <Menu> button to display [FAX SETTINGS].
2. Use the [ left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif ] to select [TX REPORT] then press <OK>.
4. Use the [ left.gif] or [ right.gif ] to select [PRINT ERROR ONLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Changing the Paper Size, Type and Source
Changing the Paper Source
Before printing, confirm that the location where you have loaded paper is selected as a paper source. Press <Feed Switch> to change the paper source.
(A) Auto Sheet Feeder Lamp
(B) <Feed Switch>
(C) Cassette Lamp
Note: Press <Feed Switch> so that the Auto Sheet Feeder Lamp lights when loading paper in the
Auto Sheet Feeder and the Cassette Lamp lights when loading paper in the Cassette.
You can also select the paper source with the printer driver when printing from the
computer.
Changing the Page Size and Media Type
Note: The asterisk <* > on the LCD indicates the current setting.
1 . Press <Paper>.
When you do not need to change the page size, press <OK> to proceed to step 4.
2 . Use leftright.gif to select the page size: A4 / B5 / A5 / 4x6 / 5x7 / C-CARD / 8.5x11 / 8.5x14
sizetypelcd.gif 3 . Press <OK>.
4 . Use leftright.gif to select the media type: PLAIN / PHOTO PRO / PHOTO PLUS / MATT PHOTO / GLOSSY
Note: In order to obtain optimal quality print results, when copying photographs, use Canon-recommended Photo Paper Pro or Photo Paper Plus Glossy.
5 . Press <OK>.
Entering the Date and Time Note: When your machine is connected to a computer with the MP driver installed, even if the date and time are entered from the Operation Panel of the machine, the date and time will be read from your computer every time you start the computer, turn the machine on, or disconnect and connect the USB cable. When using your machine connecting to your computer, set the date and time on your computer precisely.
The date and time will be reset when you disconnect the power cord or there is a power failure. In this case, you can set it again on the machine. Alternatively, it can be read from your computer and set on the machine by connecting the machine to your computer with the MP driver installed.
1. Press [FAX], then press [Menu].
2. Use [ left.gif] or [ right.gif] to select <USER SETTINGS>.
3. Press [OK] two times.
datetimeset.gif 4. Use the numeric buttons to enter the date and time (in 24-hour format). Enter only the last two digits of the year.
Note: If you misentered the date and time, use [ left.gif] or [ right.gif] to move the cursor under the number to enter the correct number. Three formats of date are available.
5. Press [OK].
6. Press [Stop/Reset].
I hope it helps!!!
Nov 25, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Panasonic KX-FL541 Plain Paper Laser Fax Logo
104 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
