Question about Hoover U8311900 WindTunnel 2 Vacuum
No suction the suction on the vacuum is very weak. What should i do?
  • talentetta Mar 14, 2008
    I have new carpet, and the bag filled up really quick, and stopped suction. I took bag out, removed all the lint fluff, and all lint out of the hoses. It appears clear everywhere, but the bag sucks in instead of puffing up when I turn the vacuum on.
    President:
  • 1,673 Answers
Check the hose for clog, take it off if you can, drop something thru it to see if it comes out the other side. Check the dirt inlet by the brush roll to see if it is clear or clogged. Filters could be bad also. Is the brush turning under load ok? If not then replace the belt, they stretch after a short time.
Posted on Feb 22, 2008
Weak suction
if you've changed filters and checked for blockages it may need a new suction fan ,,you can download the diagram off the link below
http://www.ereplacementparts.com/black-and-decker-phv1800-dustbuster-parts-c-4167_8887_8897.html
Mar 13, 2013 | Black & Decker PHV1810 Bagless Handheld...
Uv200 very weak suction
is there a blockage in the inlet pipe ???
Jul 12, 2012 | Black & Decker UV200 Wet/Dry Vacuum
Weak suction shop vac
Is the tank filled completely with dirt? When was the filter last replaced or cleaned?
May 15, 2012 | Vacuums
No suction. dirt goes into the filter instead of the canister
Check the motor and clean it properly. A very dirt motor will cause no suction or weak suction.
Be sure the motor is running on proper speed, a weak motor will cause a weak suction.
Thanks for asking.
Jun 25, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Wertheim vacuum cleaner 2000 does not seem to be having enough suction
If you are sure the is no leaks on suction line, please check and clean the filter. The common problem on weak suction vacuum cleaner are leaks and filter clog up.
Regards
Jun 18, 2011 | Vacuums
What would cause the suction to be weak?
It sounds as though there is something stuck in the hose or outlet from the motor to the hose.
May 03, 2010 | Electrolux Vacuums
My vacuum tools have very weak suction.
There is a foam ring filter in the bottom of the canister that collects the dirt. It screws off of the bottom on the canister. Take outside and shake it out. It fixed our suction problem.
Jan 31, 2010 | Bissell 3576 CleanView II Bagless Upright...
Bissel model 3594 has weak suction
clean the filter abovethe dust cup... and any other filters
Feb 16, 2009 | Bissell 3594 CleanView PowerTrak Bagless...
Poor suction
Either you have clogged filters, or the motor is weak, you could check the carbon brushes, otherwise replace the motor.
Mar 28, 2008 | Vacuums
Hoover U8311900 WindTunnel 2 Vacuum Logo
63 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
