Question about Exercise & Fitness
My treadmill Proform Crosswalk 400e stop, speed level from 1-6 and 8 as well as decline function does not send a signal and the belt does not work. nevertheless with function #7 the belt start runing.
We have the same problem, did you solved it?
Posted on May 07, 2010
I have a proform crosswalk 400e, and the circuit breaker on the treadmill trips whenever I plug it in
Many motor may have two stages, the first starts it turning and then the second stage takes over to keep it running. The 2nd stage of the motor may be faulty and drawing two much current or leaking current to the earth. Your breaker may not be the correct rating for the machine and needs uprating.
Something could have slipped in or moved around that could be jamming the belt or something else in the machine preventing it from starting up and causing an overload that triggers the breaker.
Feb 15, 2015 | Proform Crosswalk 400e Treadmill Total...
Why won't my treadmill incline or decline?
Hi there, checked both upper and lower bolted connections, and check that lift motor hasn't cracked and frame is intact with no blockages to a possible scissor arm-lift assembly underneath the unit ? If this all checks out, maybe a small gearbox on the lift motor failed internally. Good luck.
Feb 02, 2015 | Proform Excellent Condition Pro-form 400e...
Proform crosswalk 400e
see the video and fix it. God bless you
Lube the rollers bearing front+back and test the drive belt motor, and replace it if necessary.
Oct 14, 2013 | Exercise & Fitness
Proform Crosswalk display will not work. Belt and incline work fine. Have changed batteries, adjusted reed switch to within 1/8
adjust the REED switch, see the diagram for to do it. clean, and tight the connector very well.
God bless you
May 11, 2012 | Proform Crosswalk Ls Treadmill Walking...
All digi windows such as speed come on (00) but do nothing else ? Example I change speed of treadmill but readout is still (00) .
If you can start ,stop ,incline up & dn and change speed without fluctuation and the belt does not stop. Then the speed sensor is working, sending a signal that is reaching the processor but may have some op amps that are defective in the upper console display causing no read outs, If what I have read by your description that would call Icon Fitness @ 1-800-999-3756 they will confirm what I think has happen and will give you a price on replacement
May 06, 2010 | Proform Crosswalk 500 Treadmill
My treadmill Proform Crosswalk 400e feels like it is going to throw me off. Is the belt slipping?
If it feels like you are walking/sliding on ice, the walkbelt or the motor drive belt is loose.
Jan 15, 2010 | Exercise & Fitness
Exercise & Fitness Logo
439 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
